7020 hydraulic oil from trans to rear
BillinAlberta View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BillinAlberta Quote  Post ReplyReply Direct Link To This Post Topic: 7020 hydraulic oil from trans to rear
    Posted: 26 Sep 2023 at 7:06pm
Well the engine is runnung fine(more on a seperate post)but the oil is going fast into the rear case and out of the transmission .According to the manual there are 2 areas to look at.
   Pump is out and I have ordered the seal that is recommended to change but the seal that is there LOOKS not too bad.It will get replaced.
   The book also recommends pulling the range shift cover and sealing up the core plug.I have gone through that manual and can't find a location for the Range Shift Cover.Is the cover(aluminum)on the right side with all the levers and valves under the batteries the right one?If I remove it are there any special precautions ? It looks like it might be a nightmare if not done properly.
    I really appreciate all the advice given on here.Hopefully my "Big Al" will run again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2023 at 7:48pm
Going fast, as in how fast ?? Last time I heard about something like this, the oil cooler/radiator area had been worked on and two hoses got reconnected wrong.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BillinAlberta Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2023 at 10:22pm
I just ran outside in my pj's and checked.You could be right.I will have to check tomorrow.
Yes I changed engines and those lines were off.
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2023 at 7:37am
The aluminum cover is the power shift valve body. The range cover is further back behind the small fuel tank. I don't think that is your problem.
This page was generated in 0.052 seconds.
