Allis Chalmers 2 WD 8070 hydraulic
Blaine Cortines View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blaine Cortines Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers 2 WD 8070 hydraulic
    Posted: 26 Sep 2023 at 9:30am
I'm trying to ensure my fluid level is correct. Should the fluid level be in the top inspection glass? Is my hydraulic fluid and rear end fluid in the same compartment?
Any help on this subject would be nice..
Post Options Post Options   Thanks (1) Thanks(1)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2023 at 9:44am
They are the same...transmission is separate. I like mine in both glasses. Needs parked on level ground for 10-15 minutes shut off to view. You need an operators manual.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blaine Cortines Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2023 at 10:01am
Okay, Thank you And I assume I fill through the tube that sticks straight up in the air from housing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2023 at 11:24am
Yes the one to the rt. The left tube goes to the transmission. When adding don't pour more than a gallon at a time. Takes a while for it to run down and show up. I think book says a quart at a time.
Edited by SteveM C/IL - 26 Sep 2023 at 11:28am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blaine Cortines Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2023 at 11:35am
Thanks again ..
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2023 at 1:47pm
Let me make a suggestion. That plug for the fill neck can be lost easily as in I forgot to put it back in after adding oil and went to the field. It is planted somewhere. The new $$$$$ one is zip tied to a small chain which is tied to a hyd remote cable.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blaine Cortines Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2023 at 4:05pm
We got it filled, and yes ill do that! Thank you again . Have a great weekend..
This page was generated in 0.089 seconds.
