d262 vs, dt262 engine kits
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Topic: d262 vs, dt262 engine kits
    Posted: 23 Sep 2023 at 10:34pm
whats differant in the two engine kits
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2023 at 7:40am
D262 is flat top. D262T will have reliefs cut in them for the valves to clear-
With that said I have seen D17 Diesel Pistons in a D19 Turbo tractor-which is fine as long as you use the D17 cam with them
1968 D15D,1962 D19D
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2023 at 7:48am
overhauled a D19 a couple years back.  only D17 pistons could be found.  had the valve reliefs cut into piston to match oem and ran D19 camshaft. runs like a top.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2023 at 7:48am
thats all for 900$ differance and a couple of turbo gaskets
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2023 at 7:55am
so if i used a d19 kit in a d17 it would be a dog with out the d19 cam and probley the haed allso   the head would not work any ways would it
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2023 at 7:58am
the D19 used 2 cam grinds one early 1 late and had less compression because of the turbo.  early ones were hard starters so they tweaked the cam profile.  thats what i recall from researching to get ours done.  Dr. Allis might have some additonal input on it.  Im surprised you could find parts, i didnt think anyone was makine 262 kits anymore?  we ordered some of the last 262 stuff Norm had and kept on the shelf for a couple years before the rebuild.
Edited by CAL(KS) - 25 Sep 2023 at 8:01am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2023 at 10:15am
I have very little experience on those engines, and what I do have ain't pleasant. I thought the original D-19 pistons were 15 to 1 compression ratio, while the D-15-17's were 16 to 1.  To use 15 to 1 in a non-turbo engine wouldn't make the HP and wouldn't run as nice, like doing some blubbering under light loads.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2023 at 3:15pm
well its looking real grim for getting engine kits the machine shop i use is looking for the rest of the stuff to get one together for someone ealse to
Wes (VA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wes (VA) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2023 at 9:05pm
Did you try Mark Pfouts? I talked with him about a year and a half ago and he said he had sources for 262 stuff..
Edited by Wes (VA) - 25 Sep 2023 at 9:06pm
