Wanted B
200Tom1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200Tom1 Quote  Post ReplyReply Direct Link To This Post Topic: Wanted B
    Posted: 23 Sep 2023 at 9:18pm
Brackets to put a generator on a very early B. I am going to give this little tractor To my grandson. Will need the Genny too. PM me please.
KMAG View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KMAG Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2023 at 9:32pm
Make them, assuming orig engine block lacks bosses for generator/alternator bracket holes. Use angle iron.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2023 at 5:19am
Andy shows a pretty slick way to add a Gennie if the engine block doesn't have the holes for the stock brackets. I have the stock brackets if interested whether you have the engine block holes or not. You could do the same thing Andy did. He used the stock brackets, just in a different way. I also can supply a rebuilt Gennie with either a cutout or VR.  There's a core charge on the unit unless you have a core you can send in.... Your call there. Or, maybe someone here has a complete setup used that works they can fix ya up with inexpensively.  I don't sell any used electrical parts....
Steve@B&B
This page was generated in 0.478 seconds.
