Front wheel bearings for a G |
pungobob
Joined: 15 Mar 2023 Location: Belhaven NC Points: 83 |
Topic: Front wheel bearings for a GPosted: 23 Sep 2023 at 8:53pm |
Good evening all. Those of you that had a visit from Ophelia hope everyone fared well. We lost a tree and had some minor flooding but all things considered we did ok. Now to my question. I am in the middle of a restoration project on a 1951 model G. I pulled the front wheels and was going to clean and repack the bearings. I literally had to beat the hubs off the tractor using a sledgehammer and large metal drift that my wonderful wife held for me. I had to heat one side to the point that it ruined the bearing but I finally got both hubs off. After cleaning everything I started measuring the bearings and the spindles. The inner bearings are Bower #1380 the outers were Timken #09081. The Bower inside diameter was .873-.874 the spindle measured .875. The inner bearing was .808-.809 and the spindle was .810. What are the correct bearings and grease seals I need to use? There’s no way I should have to drive the bearings on the spindle. I cleaned the spindle with emory cloth but still the bearing would not go on. If someone has the correct bearing and seal numbers I would be very great full if you would share the information. Thanks in advance.
Mikez
Posted: 23 Sep 2023 at 9:39pm |
800445 seal
800449 inner bearing. Still available 800048 inner race 211897 outer race. still available 800186 outer bearing. still available 248104 kit
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 90908 |
Posted: 24 Sep 2023 at 7:43am |
sometimes it helps to put the NEWER "70" in front of the old ALLIS part numbers, if your searching the internet..... example. 70800449
