1978 816b series motor won’t stop running. S
816b View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 816b Quote  Post ReplyReply Direct Link To This Post Topic: 1978 816b series motor won’t stop running. S
    Posted: 23 Sep 2023 at 8:43am
My machine won’t stop running. Half to turn off fuel. Not sure what needs replaced. Any help appreciated.
orangeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2023 at 11:06am
816B - do you have a manual (parts) and operators for the machine?  There should be a manual shut off (cable) to shut off the fuel flow from the injection pump to the injectors.
HTH ~ Orangeman
Eric B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2023 at 4:16pm
As Orangeman mentions the manual shut-off... right on top of the pump is the lever. With engine running the top of the lever should be pointing towards the radiator, in the shut off position the top of the lever should be pointing towards the the back of the hood/fuel tank. It's possible that the cable has malfunctioned.
