7030 stop all HYD
dchilton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dchilton Quote  Post ReplyReply Direct Link To This Post Topic: 7030 stop all HYD
    Posted: 21 Sep 2023 at 10:34pm
   Drove it up and hook up a piece equipment. Got back on started to move only move a foot or two it stop lost all Hydraulics. No power take off, 3-point lift steering and transmission. I was wondering if you think it the torque limiter or the hydraulic pumps?
Thank you for any help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2023 at 12:17pm
Torque limiter
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2023 at 12:39pm
In my mind it could be the hydraulic pump drive coupler. Not to disagree with any one
It could be torque limiter or pump coupler. I would think torque limiter would give some sign of trouble. Itll be interesting to find out
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2023 at 2:01pm
For 1000% percent accuracy, remove the 3 pt top link anchor. Remove the frost plug behind it. Start the engine. If the shaft doesn't turn it's the torque limiter.
This page was generated in 0.052 seconds.
