Wheel weight bolts |
Post Reply ![]() |
sparky ![]() Orange Level Access ![]() ![]() Joined: 13 May 2011 Location: So. Indiana Points: 1788 |
![]() ![]() ![]() ![]() ![]() Posted: 21 Sep 2023 at 7:37pm |
My 185 has 18.4 X 30’s and I have a set of one piece Taylor weights to put on it. Will the bull gear housings keep me from installing the weight bolts or do I have to pull the wheel center off? TIA.
Edited by sparky - 21 Sep 2023 at 7:38pm |
jiminnd ![]() Orange Level ![]() Joined: 16 Sep 2009 Location: Rutland ND Points: 2307 |
Not sure what taylor weights are but I think you can get bolts in if wheel is in right spot. Also the width of wheel setting just to reach in there.
AC720Man ![]() Orange Level ![]() ![]() Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5245 |
Spin out rims? If so spin them out and then you should definitely be able to get them on.
Yes it has spin outs. I’ll check it out more closely. I’ll probably yank the bull gear pans and change the gear oil. That should give me more clearance. Thanks.
Even spun all the way out I had to remove the tires/wheels on my D 17 to change the oil and replace the gasket.
Well if push comes to shove I’ll block her up and buzz the tire/wheel/center off and lay it down and mount up the weight and then yank the pans off. Sounds like a winter job in the shop is on the agenda. Thanks
Post Reply ![]() |
