D19 Hydrolics
Pa'sOldA/C View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pa'sOldA/C Quote  Post ReplyReply Direct Link To This Post Topic: D19 Hydrolics
    Posted: 21 Oct 2010 at 3:26am
 My D19 gas burner has a hydrolic leak. The lift will not stay up and It is leaking fluid all over the shop. It will leak for days after you shut it off. Anybody have any ideas what it might take to fix it.
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2010 at 5:52am
Where is the leak coming from?
1968 D15D,1962 D19D
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pa'sOldA/C Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2010 at 6:25am
 Not sure fluid is coming from the belly of the tractor. I figure there is a seal or internal hose that has the leak. I have a shop manual ordered.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2010 at 2:46pm
3 spool setup or single?
1968 D15D,1962 D19D
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2010 at 3:43pm
More likley and external line going to the remote valve bank.   The lift not staying up is probably the lift check valve in the valve bank, ya gotta split the valve in half.  That is one part they did a poor job of describing its function and how to repair it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pa'sOldA/C Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2010 at 7:35pm
I beleave it is a 3 spool
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pa'sOldA/C Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2010 at 11:15pm
Well got my manual in and its not a whole lot of help. I think I found a guy that can fix it. Thanks for all the help.
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2010 at 11:41pm
Check the pto shifter seal?
