18.4-38's on a 190XT
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Topic: 18.4-38's on a 190XT
    Posted: 20 Oct 2010 at 10:41pm
I was wondering if it can be done, to put 18.4-38 tires on the rear of a 190 xt? The reson I would like to do this, is to get the back end of the tractor a little higher for windrow clearance when baling, and also it would make both the tractor and the baler sit level. It would also give me a much needed faster road gear. I realize it would gear me up some and maybe cost me a little power, but I would hope that what I do now in 3rd gear (or 5th and 6th technically), I  could do about the same in 2nd gear (3rd and 4th) with the taller tires. Any thoughts? Thanks, Darrel
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2010 at 10:59pm
I've got factory 38" rims on my 190XT with 18.4 radials and no fluid....can't say that it is any faster going down the road, but it pulls well, and is also slow enough in 1st gear for good performance from my Northwest 8' Rotovator.  It came with the big rubber 13 x 16?) up front, but I now have my 20" NOS rims and truck tires on it for a wider wheelbase.
ALLIS EXPRESS!
This year:
scott View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote scott Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2010 at 6:22am
Those front tires and rims have sure been on a lot of tractors...
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2010 at 6:23am
My 1967 xt has 18.4x38. I can't prove it's not from the factory. It has the shift pattern decal for using 18.4x38 but it was repainted at one time way back. Works great.
Wink
I am a Russian Bot
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2010 at 7:26am
Same as a 200 or some company makes extension blocks from 34 to 38.
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2010 at 8:53am
How about 20 inch....Dale
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2010 at 9:55am
Scott I had them on my 175D brushhogging tractor when I used the 6 ft mower...but had to put the loaded 9.5L-15's back on when I got the 8ft JD MX8 mower. I put these on the 190 to get the front wheels out far enough for the rollover plow (someone replaced the tie rods with ones that were too short) and they have stayed on there ever since.
ALLIS EXPRESS!
This year:
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2010 at 10:59am
38 inch wheels were optional on 190s, so its not a stretch.  I have 18.4X38s on my D19 diesel and they look good too.  It doesnt do much field work anymore, but pulls ok.
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2010 at 11:38am
18.4-34 tires are 193.8" circumference, axel turns 327 times for a mile.   18.4-38 is 205" around and turns 309 times for a mile. If your tractor is running at 15 miles an hour, the bigger tires will get you up to 15.9 mph.  Now if you put some 20.8X38 tires on, they are 215.7" around and would get you up to 16.7mph.
 All are app. figures... taken from a Goodyear web site.
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2010 at 11:56am
Assuming the rpm of the engine is the same though. If the engine drops because of the higher hp demand due to the upgearing of the tires, the speed may settle back to the 15mph number.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2010 at 11:59am
190 xt's don't drop in RPM very easy.
Wink
I am a Russian Bot
troy(el paso, il) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote troy(el paso, il) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2010 at 12:34pm
Skip-
Do you have any pics. of your D19 with those 38's......would love to see it....Troy
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2010 at 3:50pm
Dog gone it  Troy, I need to learn how to use the digital camera to post pictures on here!! I own JPG some pics of my D17 III with cab.    the tires are radials too!!!!   Ya cruise around on tractor rides about 1/2 trottle, them guys on them there red ones dont get to far ahead of it!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2010 at 6:33pm
This is Skip's D19...   Mike
Oh...and the 185...
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Post Options Post Options   Thanks (0) Thanks(0)   Quote troy(el paso, il) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2010 at 7:09pm
Hey, thanks Mike for the pics. of Skip's tractors.   Skip that D19 looks like a monster with those tires.........like it a lot.........Troy
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2010 at 11:03pm
I guess that going by JC's numbers, the speed won't change enough to be a big factor, but I would sure like to put em on to get the back end of the tractor up a little higher. Thanks, Darrel
Wes (VA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wes (VA) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2010 at 11:19pm
I think this is a picture from the Gubbels' ..I hope they dont mind..but it is a sharp 190..If I ever had one I'd want it to look like this one.   -Wes
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2010 at 8:19am
Dan, I was reading your post again, and wondering, when you say "extension blocks", are you meaning that you can get those wedges that go between the cast iron wheel and the rim that will allow me to use the same cast wheel, but a 38 inch rim and tire? Thanks, Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2010 at 9:52am
I need to get the pickup tires off the front, just havent done that yet.  It has a real nice turbo whine too!!!  Thanks for getting pictures on Mike!!!!!
Jim in SE ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim in SE ND Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2010 at 7:53pm
I know you can get the wedges to use the same centers and just buy rims, neighbor did this to 2 or 3 4020 JDs, don't know where but I would think any good tire store should know .
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2010 at 8:33pm
you can also get step up rims, cheaper than all the blocks and buying rims too.
Henry se/k! View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Henry se/k! Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2010 at 10:09pm
I have a set of these wedges for sale. 620 439 5638
AndrewGubbels View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AndrewGubbels Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2010 at 10:24pm
I would say 18.4-38's is the way to go!!! They are harder to find with the 38's Here are a couple photos of some of the ones we have with the 18.4-38's.   THey will go right at or around 17 mph with the 38's.
Andrew
Andrew Gubbels
Gubbels Restoration
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2010 at 10:25am
Andrew, them are some very nice looking one-ninety XT's, thanks to all for posting the pics. I quite certain that by hay baling time next year, I'll some how or another have 18.4-38's on the rear and some pretty good sized diamond tread tires on the front of my one-ninety XT. I guess I'm too fussy, but I think I'm going to look for some different cast centers and everything (used of course) so that it looks original. However I haven't ruled out buying the step up wedges that Henry posted having for sale. Thanks, Darrel
