What model do I have?
CronyTJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CronyTJ Quote  Post ReplyReply Direct Link To This Post Topic: What model do I have?
    Posted: 19 Sep 2023 at 7:03pm
Hi everybody I just scored a D series but I’m not sure if it’s a 10, 12, or 14.
It’s only my second Allis I’m typically a Ford and Farmall guy.
It has no starter so if anyone has one I’d be interested in buying it. Thanks in advance. Here are some photos. let me know if they load.
Tom
KMAG View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KMAG Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2023 at 7:13pm
D14 or D15 - a photo of tractor nose would help.
Edited by KMAG - 19 Sep 2023 at 7:16pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CronyTJ Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2023 at 7:24pm
Ah ok even better. If it’s too dark to get a photo now I’ll get one in the morning. Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CronyTJ Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2023 at 7:27pm
only AC orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote only AC orange Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2023 at 7:27pm
Whatever it is, it has shuttle shift on left side!
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2023 at 8:01pm
how about a serial number
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2023 at 9:27pm
What happened to the muffler?
Why not get a starter for it? From what I have heard over the years, if the shuttle works, those are very good loader tractors.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2023 at 9:47pm
Heavy duty front axle too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2023 at 9:54pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2023 at 9:55pm
I think it’s a D15 industrial, shuttle shift and heavy duty front axle.
Travis2766 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travis2766 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2023 at 10:30pm
D14 Industrial??? Serial number will tell what it is, its on the torque tube (left side) where it meets the motor.
190XT Series III, D17 Series IV, D15 Series II, All Crop 66, Rotobaler.
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2023 at 6:34am
what is width of grill 15 is wider then 14 by 2 inch
nonetheless ,still dead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CronyTJ Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2023 at 6:40am
So on left side of bell housing there’s a raised rectangle where it looks like serial number should be. But no number.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travis2766 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2023 at 7:08am
It will be where the yellow box is in the picture, it’s stamped into the casting and is very hard to see sometimes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CronyTJ Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2023 at 7:55am
Nothing there
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2023 at 8:01am
ON TOP, not the side.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travis2766 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2023 at 8:01am
That’s below where the highlighted yellow box is. Go higher up on the same flange, above the upper bolt in your picture.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CronyTJ Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2023 at 9:42am
Whoops. Just saw your reply. I’ll look today and check back. Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CronyTJ Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2023 at 12:38pm
Well look what I found
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2023 at 1:15pm
Thumbs Up   Clap
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travis2766 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2023 at 1:52pm
D15 7053??? If I’m seeing that right you have a 1961 series 1 D15 Industrial, the standard D15’s have the “big stick” on the right side of the torque housing and that created a high and low for each gear. The industrials have it on the left side and it created a forward/reverse shuttle.
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2023 at 3:30pm
Maybe I missed it , but is it a diesel ? If so , you may have a hard time finding a starter . Hope not , good luck .
Post Options Post Options   Thanks (0) Thanks(0)   Quote CronyTJ Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2023 at 4:41pm
Nice! Thanks for all the info.
It’s a gas job. Hope starter isn’t hard to come by.
And I was wondering what the big stick on left was. The shuttle will be handy.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2023 at 4:54pm
I would think a gas starter would be pretty easy to find. Steve at B and B might have one.
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2023 at 5:12pm
That is one bodacious winch on there Cool I like it!
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2023 at 7:27pm
In the first picture it looks Ike the front support power steering vent has been screwed into the transmission oil level hole below and to the left of the key?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2023 at 9:31pm
Robbie our D14 industrial, shuttle clutch has the same vent
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2023 at 9:35pm
That surprises me, don’t recall the D15 industrial I tried out having that. Thanks for correction. Guess I was to busy testing the shuttle clutch lol. I should have bought it...it went cheap
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2023 at 9:38pm
Not saying it’s right lol. Interesting
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2023 at 9:45pm
Just looked in d14 parts book. Gives three different part numbers. First just says gauge assy, oil level. Second says same and base tractor in parentheses. Third says same and for utility tractor with shuttle clutch in parentheses
