TSX428 carb on Allis "B"
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Topic: TSX428 carb on Allis "B"
    Posted: 18 Sep 2023 at 6:33pm
I have a couple of the small B tractors that have carbs that have been "rebuilt" several times and internals / threads / jets are getting worn down.. I have been thinking for a couple years about the TSX428 carburetor sold on E-bay and others for $25-35. for the old FORD 134 CID tractors... Manifold bolt pattern is the same,  throttle nozzle looks to be the same size, choke and throttle levers are on the backside of the carb....
Only difference seems to be the throttle lever is pointed DOWN instead of UP.. and the NEW carb uses a ball socket to attach the two rods.... So i bought one and intend to modify the two levers , install on one of the tractors and run a "TEST" .... For $30. i figure i cant go wrong..
This is what i bought............
Edited by steve(ill) - 18 Sep 2023 at 6:39pm
Post Options Post Options   Thanks (1) Thanks(1)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2023 at 6:36pm
This is what arrived today.....
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2023 at 8:27am
Will be interesting to see how this works. I have bought a couple of the bargain carbs, both seem to work. Really don't know how they make them so cheap, even if labor is free the materials and shipping.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2023 at 8:38am
Very simple: China exports their unemployment to other countries by subsidizing their industries to keep their own people working. When people buy those cheap products it continues the cycle.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2023 at 9:04am
If you buy a REBUILD KIT to repair your 75 year old carb... The KIT cost as much or more ... and the KIT comes from CHINA... They dont make much in this country anymore..
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2023 at 1:26pm
Well, i finally got 2 hours of free time to work on the carburetor.. Took a BEFORE photo with the throttle arm pointed down.... then and AFTER photo of removal, new arm made and solder onto the  keyed shaft..  Arm that came with the carb was too short to just flip, so i made a new one of 1/8 inch plate... The CHOKE arm points UP instead of DOWN. If you remove and flip it would work backward, so i left it the way it was. Just removed the ball socket and built a little pinch clamp for the choke rod..
AFTER new throttle arm installed and  pinch clamp installed for choke-- below
Pinch clamp for choke made from 5/16  bolt turned down to fit 3/16 hole in arm.
Maybe i can get a few minutes this afternoon to fire it up and go cut some weeds !
