6060 neutral safety switch
Dwayne TX View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dwayne TX Quote  Post ReplyReply Direct Link To This Post Topic: 6060 neutral safety switch
    Posted: 16 Sep 2023 at 11:34am
Where is the clutch safety switch located? Think it's out & I'm not finding it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2023 at 11:47am
Aggravating to get to but remove the bolts holding the large access cover on under the steering wheel. Take a flashlight and look there at the clutch pedal. A lot of times the switch comes loose due to vibration making you think it went bad. We have had that happen twice. Second time I added blue lock tight and it’s been fine since.
Edited by AC720Man - 16 Sep 2023 at 11:50am
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2023 at 4:29pm
PTO safety switches on that series also need to be checked if it won't crank over.
dchilton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dchilton Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2023 at 10:48pm
On my 6080 it was under floor board on right side in front rear tire. If I remember right.
