More hydraulic power 180/185
jrbynf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jrbynf Quote  Post ReplyReply Direct Link To This Post Topic: More hydraulic power 180/185
    Posted: 15 Sep 2023 at 8:19am
Trying to set up a Kinze planter on a 180/185.  Manual says I need 20+ gallons per minute flow.  Obviously stock pump not enough.  Could go with a pto pump.  Long shot but could a D17 series 4/early 170 pump mounted on the side of the transmission provide enough flow when combined with the existing pump on the tractor?  I doubt it would even mouth up the same.  Just curious to avoid the clutter of the pto pump.  Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2023 at 8:38am
No. There's nothing inside a 180/185 belt pulley hole to drive a pump like that. You could build something to connect to a belt pulley accessory to have a drive, but it would die every time you pushed in the foot clutch. How about move the alternator to the area above the injection pump (like a combine engine) and make yourself a belt driven 10-12 GPM pump to sit where the alternator used to. Output flow could be combined with the OEM pump, but you'd have to have a separate suction/supply line.
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2023 at 9:15am
Get a pto pump and you won't burn up the tractor hydraulics. And if you have to use a different tractor you can move the pump. Planter probably doesn't use that much all the time only when using all functions at once. Neighbor went thru that this spring with a new Deere planter and Challenger tractor. They had to prioritize hydraulic functions.
Edited by DanWi - 15 Sep 2023 at 9:16am
Post Options Post Options   Thanks (0) Thanks(0)   Quote jrbynf Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2023 at 9:26am
Thanks for the replies.  Would like to make a clean install as possible
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2023 at 4:51pm
Put a PTO pump on a JD 7200 planter (new to me this year) this spring. Was quite a project in some ways but once I got it set right it worked perfectly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2023 at 8:08pm
PTO pump is best way. I drove a air fan for a 385 Deutz planter from PTO.               MACK
This page was generated in 0.054 seconds.
