D12 pull a tiller? |
Tracy Martin TN
Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10920 |
Topic: D12 pull a tiller?Posted: 14 Sep 2023 at 7:32pm |
Will a D12 pull a 5 foot tiller well. Have any of you guys done it? Thanks, Tracy
Macon Rounds
Joined: 18 Feb 2010 Location: Pittsburgh Pa Points: 2303 |
Posted: 14 Sep 2023 at 9:11pm |
I run a 6' Kabota tiller with my D10.
No problem. I love the D10/D12 PTO wish all the D series had that feature. |
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55191 |
Posted: 15 Sep 2023 at 4:38am |
If your 10/12 has it, a HiLo really helps with a tiller. Sometimes 1st isn't slow enough...
Tracy Martin TN
Posted: 15 Sep 2023 at 1:04pm |
Mine at present doesn't have high - low. Wanted one narrow enough to make a raised bed hiller. Thanks, Tracy
Allis dave
Joined: 10 May 2012 Location: Northern IN Points: 3121 |
Posted: 15 Sep 2023 at 3:42pm |
I owuld be worried about the tractor going slow enough, most of these old tractors have a pretty fast 1st gear high and tiller do better pulled slow. Of course I don't have a D12 or a tiller. You might not know until you try it
Gary Burnett
Joined: 11 Sep 2009 Location: Virginia Points: 3190 |
Posted: 15 Sep 2023 at 4:53pm |
Definitely would not be my first choice
Dusty MI
Joined: 13 Sep 2009 Location: Charlotte, Mi Points: 5061 |
Posted: 15 Sep 2023 at 5:19pm |
A few years ago I bought a 720 with a loader on it, it has a 3 point. It also came with a 3 point Roto-Tiller, with, I was told new engine on it. If any of you wood like it, make an offer. I've never used it.
Macon Rounds
Posted: 15 Sep 2023 at 11:29pm |
my D10 III has hi/low...
Would not recommend running one without hi/low... no problem with power just gotta go slow. OAN: i dont believe D12 Would cover 5' foot print. Unless you like tracks on your tilled ground. |
Tracy Martin TN
Posted: 18 Sep 2023 at 11:06pm |
Benny, I want to use it to hill up raised beds. Not worried about the tire tracks between the beds. They get covered with weed barrier . Thanks, Tracy
560Dennis
Posted: 20 Sep 2023 at 6:45am |
what type a soil ?
Probably fall is best
DSpears N IL
Silver Level Access
Joined: 11 Sep 2009 Location: Rockford,Ill Points: 418 |
Posted: 20 Sep 2023 at 8:02pm |
I make at least 2 tilling passes in opposite directions.
The 1st pass is at 1/2 throttle, and the final pass in the opposite direction at full throttle! It is much easier on the equipment and hopefully do not find anything left buried in the ground! The CA can handle the 4 ft tiller fine! Tire tracks are to the outside and not a problem! ![]() |
Tracy Martin TN
Posted: 20 Sep 2023 at 10:45pm |
That looks great!Tracy
Macon Rounds
Posted: 21 Sep 2023 at 4:47am |
CA is most underated tractor.
Great power !!! for its size. |
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25175 |
Posted: 21 Sep 2023 at 6:02am |
I have a 5' on my D-14, offset to cover the right rear , works great though I have to feather the 'big stick' for 1st passes. You need to go slooooow with a tiller as others have said. Adding lots of compost will really help. I'd till N,S,E,W to mix everything really well and 'level' the land. One option is how you setup the garden. If you use a 4' or 5' , with 'no offset', the tire tracks become the pathways to get TO the weeds, er, veggies ! You really do not lose any 'garden growing' area,minimal weeds in the paths and beds are clearly marked out. Did this for years.
