D19 Project |
Stu ECWI
Joined: 15 Sep 2009 Location: Fond du Lac, WI Points: 56 |
Topic: D19 ProjectPosted: 14 Sep 2023 at 5:09pm |
I'm hoping somebody can save some run-around. Thought it was a "real big" issue when I couldn't steer a project D19, with the front wheels off the ground, they would turn with a long bar against the spindle. Last week went to it and removed the front end. Amazing, the steering seemed to work flawlessly when turning the stub shaft, like there was no problem. After a while I grabbed the steering wheel to discover the universal joint closest to the bell housing was rusted tight!!
![]() So, does anybody know a part number or even size of cross I'll need to repair the joint??? I haven't started digging yet, and hoped somebody could save some time!! Thanks, Stu
I've got more time than money, and lately not alot of time!
AC720Man
Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5250 |
Posted: 14 Sep 2023 at 10:13pm |
I got one from DJS for my D17, fits D19 also. I choose to replace just the shaft cross bearing. $17.75. Comes with a grease zirk. Easy to install. Otherwise the entire universal joint is $130.
MACK
Posted: 15 Sep 2023 at 8:26pm |
Some of the after markets are too long and won't work. MACK
Model 70
Joined: 09 Jan 2021 Location: Minnesota Points: 151 |
Posted: 16 Sep 2023 at 1:24pm |
Weasler 200-0600
AC720Man
Posted: 16 Sep 2023 at 8:30pm |
And they are a ***** to get off! That’s why I did just the cross bearing which is all that needed replacing anyway.
Stu ECWI
Posted: 16 Sep 2023 at 9:56pm |
Thanks guys I ordered the cross from DJS, supposed to arrive Monday. Weasler is about 15 miles South of me, that would have been great too!! Thanks!!
AC720Man
Posted: 16 Sep 2023 at 11:19pm |
Take your time when replacing it. After removing the old one, be careful as you place caps with bearings in them. They are greased in place and must be lined up correctly before you press the cross into them. It’s a little more difficult to do while the universal is still on the tractor but that’s how I did mine. I put a small socket facing outward in from the opposite side and used a C clamp to draw it together. Worked great.
