Injector Pump A-C 5050
1953ACWD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1953ACWD Quote  Post ReplyReply Direct Link To This Post Topic: Injector Pump A-C 5050
    Posted: 14 Sep 2023 at 11:53am
Hello - I noticed the injector pump on my 5050 is leaking up at the stop-engine linkage and have a couple of questions, as follows:
1)  Will it do any harm to the injectior pump or engine if I run the tractor with the injector pump leaking?
2)  Is this something I can easily take off the engine and take for repair or should a garage do the removal and reinstall?
3)  Is this something I should take to an Agco shop for repair or will any good diesel shop be good to fix it?
Thank you.
1953 WD - Grandpop bought new, sold to neighbor in 1965, I bought back in 2001, restored 2021; 1974 175 Gas; 1980 5050 Diesel, w/400 Loader
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2023 at 11:59am
I keep the gasket for top and O rings for both shafts ,I do it with pump on tractor . Its a CAV pump common on many engines. Just done one on a MF last week for a customer .
 If not fixed it just makes a mess. seen housing get wear from o-ring not supporting shaft in housing
nonetheless ,still dead.
This page was generated in 0.154 seconds.
