8000 series steps on a 200 |
Post Reply |
captaindana
Orange Level Joined: 14 Sep 2009 Location: Fort Plain, NY Points: 2461 |
Posted: 13 Sep 2023 at 4:33am |
Has anyone done this? I know anything can be done depending on how much money and fabrication is needed. My 200 steps which I added another lower step this spring still are uncomfortable for me between my left meniscus knee and right bursa enflamed hip. Thanks! Dana
Blue Skies and Tail Winds
Dana |
orangereborn
Orange Level Joined: 12 Sep 2009 Location: NW WI Points: 1438 |
Unit3
Orange Level Joined: 17 Oct 2009 Location: NC Iowa Points: 5532 |
I added steps from my black frame 7060 to my 200 with factory cab. I’ll go out and get you some measurements.
Unit3
I have a 3 in.² tubing with quarter inch thick wall. It measures 19 inches long. And I had to drill 2 half inch hole and the bolts come up into the bottom of the cab. I drilled and tapped holes for 3/8 bolts that goes through the steps into the side of the square tubing. Then I made a brace from the bottom step up to the battery box. It really has a good feel to it. My 7045 is sitting right next to it and the bottom step height is the same.
DSeries4
Orange Level Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7332 |
Have you tried the Noonan steps? I put one on my 190XT and I am very happy with them. Direct bolt on and nice evenly spaced pads. The factory steps leave little to be desired by comparison. |
steve(ill)
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 81101 |
that step above works great if you have two good legs... If you have one weak leg you might want a set of WIDE steps so you can step up, then pull your other foot to that same step, then step up again, etc..... Each step is wide enough to get both feet on at the same time............... plus it can be sloped more like stairs instead of a step ladder.
Edited by steve(ill) - 13 Sep 2023 at 4:17pm |
orangereborn
I think Mike sold the step business and if I recall correctly, maybe to Alex @ Cecil WI??
sparky
Orange Level Access Joined: 13 May 2011 Location: So. Indiana Points: 1547 |
I believe Dale is correct.
shameless dude
Orange Level Joined: 10 Apr 2017 Location: east NE Points: 13607 |
I bought 2 of the steps like Dseries shows, one set on my 180 and one on my 190XT, i'm going to mount the original step from the 190 onto the side of the battery box just ahead of the fender to help get me onto the platform.
captaindana
Steve I’ll has got the right idea for me. That’s what I need. Unit3 could you please post a pic? Thanks. Dana
Dana |
DrAllis
Orange Level Access Joined: 12 Sep 2009 Points: 20485 |
I think the 200's step is pretty straight up,making it hard to pull yourself up into the cab.
captaindana
Yes the 200’s steps are straight up. They need to go away😫
Dana |
AC7060IL
Orange Level Joined: 19 Aug 2012 Location: central IL Points: 3340 |
Here ya go CaptainDana.
https://www.allischalmers.com/forum/allis-200-steps_topic37947.html |
steve(ill)
from ACs post.....
Edited by steve(ill) - 14 Sep 2023 at 8:04pm |
captaindana
Yes they’d be perfect!
Dana |
Post Reply | |
