Wd Clutch
fixer1958 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fixer1958 Quote  Post ReplyReply Direct Link To This Post Topic: Wd Clutch
    Posted: 20 Oct 2010 at 1:54pm
Doesn't a WD and WD45 pressure plate interchange?
Considering going with a 9 spring pressure plate.
Has anyone ever used a button clutch disc in one?
I put a button clutch in an old dump truck I had and you didn't slip the clutch much.
It was either in or out.
Just wonder how it would be in a WD.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2010 at 5:34pm
Yes, the PPlates interchange......you have to use the 4-button type (from a K Gleaner fits)  in a puller if you get over 75 HP or so. Yes, they are aggressive. You may not like if for farm use.
norm [ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2010 at 7:24pm
    will wear flywheel for sure   never sold one for that reason
