IB amp gauge
Freewheeling View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Freewheeling Quote  Post ReplyReply Direct Link To This Post Topic: IB amp gauge
    Posted: 10 Sep 2023 at 9:44am
I'm restoring an Allis IB to as original as possible. I've looked on line for a B amp gauge and found a lot of variations. 60 amp, 30 amp, 20 amp, with Allis-Chalmers on the face and without, colored dial and numbered, etc.  The tractor is a 1952.  Can anyone tell me what the factory original gauge looked like?  Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2023 at 12:42pm
i believe it looked like this......... ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Freewheeling Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2023 at 2:28pm
Hi Steve,
Thanks.  I wonder if it was a 30 amp since the system theoretically doesn't put out that much.
By the way, I am wrap my head around the electrical system.  I read an article that related it to water through a pipe. Made it easier to understand volts and amps and principle of the generator.  Using that analogy it seems that the 3-way switch acts like a valve in a pipe.
I did some tests on the generator last week both assembled nd disassembled.
I set the multimeter @ lowest ohm scale - 200
Between 3rd brush and F terminal
Disassembled - 2.2-2.3
Assembled - the same
F terminal to ground ( case)
Disassembled - no reading
Assembled - 3.3
Assembled
3rd brush to ground - 0.3
Other non-grounded brush to ground - 0.3
Ground brush to ground - 0.0
"A" terminal to ground - 0.3
My understanding is that these are all good readings. Correct?
Hopefully I can get back to the shop next week and check the wiring.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2023 at 5:06pm
i dont know if the ORIGINAL amp gauge was 20 or 30 amp.... Personally i like the 20 amp BLACK aftermarket gauge.. Thats what i have been using.. But many will say the "original" was white with a chrome ring and the words ALLIS CHALMERS on the face.. but if it was 20 or 30 amp , i dont know.
off hand, i think your numbers look pretty good..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2023 at 6:01pm
The original amp gauge was a 20/20. Most were Black face white letters. No Allis-Chalmers name on the face. It looks like our 1500-01A on our website. HTH
Steve@B&B
bb-customcircuits.com
