Leaking lift cylinder |
tom51
Bronze Level Access
Topic: Leaking lift cylinderPosted: 09 Sep 2023 at 11:07pm |
Need some advice from the experts . I have a leaking lift cylinder on a WD that needs to have new packing installed. What’s the best way to proceed. Thanks
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4275 |
Posted: 10 Sep 2023 at 6:31am |
Try just tightening the nut first.
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 90808 |
Posted: 10 Sep 2023 at 8:48am |
MACK
Posted: 10 Sep 2023 at 8:25pm |
Unscrew nut from rear of cylinder. Place a catch pan under cylinder. Raise lift lever to top, when old packing blows out, lower lever and arms. Remove rear cylinder pin, nut, old packing. Reassemble in reverse order. MACK
tom51
Bronze Level Access
Posted: 10 Sep 2023 at 11:15pm |
Packing nut was as tight as it would go no adjustment left. Thanks for the advice will order a packing kit and repack
sparky
Joined: 13 May 2011 Location: So. Indiana Points: 1834 |
Posted: 11 Sep 2023 at 8:07am |
Just offering advice but I would rebuild both cylinders. My luck would be the other cylinder would be soon to follow. I learned that lesson on a CA. I just recently rebuilt the cylinders on my 185.
Edited by sparky - 11 Sep 2023 at 8:09am |
CTuckerNWIL
Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
Posted: 11 Sep 2023 at 8:38am |
The last couple sets of packing I got for a cylinder, I got from Motion Industries. I don't think anywhere else can come close to the low cost they sell for.
Motion Industries has a store finder on their website. Stores all over the US as far as I know. |
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8981 |
Posted: 11 Sep 2023 at 1:05pm |
If rams are like most....pitting and scoring make it hard for new packing to do its job.
MACK
Posted: 11 Sep 2023 at 8:23pm |
WD cylinders don't rust and pit like alot of cylinders because they seal to shaft not bore. MACK
tom51
Bronze Level Access
Posted: 11 Sep 2023 at 11:30pm |
Will do both cylinders rods are not pitted or rusty packing ordered today. Thank you for all your help
