A/C 180 has torn hydraulic screen |
ClayP
Topic: A/C 180 has torn hydraulic screenPosted: 07 Sep 2023 at 7:35pm |
A/C 180 has torn hydraulic screen. Can it be repaired or do I have to purchase a new one? Where could I order one? 1967 model.
DrAllis
Posted: 07 Sep 2023 at 7:56pm |
An AGCO dealership if it is still available. This screen is important and must be in GOOD condition. Anything that gets thru it can lock up the hydraulic pump and possibly break the camshaft in the engine if it does lock up.
ClayP
Posted: 07 Sep 2023 at 8:23pm |
Thank you, the hydraulic fluid had a little water in it and I decided to see if it had any sludge in the drain sump. Fairly clean but I noticed the screen was torn away from its frame. Probably should order rubber seals for return and suction tubes??
DrAllis
Posted: 07 Sep 2023 at 8:47pm |
I would 50+ yrs old.
Ryan Renko
Joined: 12 Sep 2009 Location: Edwardsville, I Points: 2349 |
Posted: 07 Sep 2023 at 8:57pm |
Mine was torn and the screen pulled away from the frame in my D17 IV. Sadly it was no longer available. I used a little engineering and managed to make a new one myself but that might not be for everyone. Ryan
DrAllis
Posted: 07 Sep 2023 at 9:25pm |
D-17 IV not the same screen as a 180.
ClayP
Posted: 07 Sep 2023 at 9:26pm |
My first thought was to repair it. I'm going to a local tractor salvage that has a 180 in it and see if I can purchase the screen if it's good.
Ryan Renko
Posted: 07 Sep 2023 at 9:34pm |
KJCHRIS
Posted: 07 Sep 2023 at 11:55pm |
Screen was available 4 year ago. These are old numbers, will need updated.
#246134 gasket. #249934 screen. These are the rubber line seals used on this cover. #245846 seal #245847 seal.
DrAllis
Posted: 08 Sep 2023 at 1:35am |
D-17 screen very fine mesh and measures 8" x 8" approximately. 180 is coarser screen and measures 3" x 7" approx. Both do the same thing but vastly different from each other,
ClayP
Posted: 08 Sep 2023 at 3:26am |
Thanks for all the help. I will check out those part#'s to see if they are still available.
ClayP
Posted: 08 Sep 2023 at 3:33am |
Are these AGCO part numbers?
KJCHRIS
Posted: 08 Sep 2023 at 3:48am |
Yes, The numbers I listed are from my old AC 180 & 200 parts books, AGCO has updated them but your dealer can cross them easily.
Mikez
Posted: 08 Sep 2023 at 6:38am |
Ad a 70 to the beginning of each number. They’re still available. Little pricey though
Mikez
Posted: 08 Sep 2023 at 6:47am |
I just looked in 180 parts book and 70259407 is rubber seal instead of 245847.
Just agco updated number Edited by Mikez - 08 Sep 2023 at 6:49am |
ClayP
Thanks again for all the help.
Ryan Renko
Posted: 08 Sep 2023 at 9:21pm |
Edited by Ryan Renko - 08 Sep 2023 at 9:30pm |
ClayP
Posted: 09 Sep 2023 at 10:29am |
Thanks for all the help with the hydraulic screen issue. I found a screen locally that was a different style and was able to sandwich the screen between two gaskets and apply permatex to all surfaces. Does anyone know if I can find an oil pressure switch for my A/C 180 at an auto parts store. Part#? Light had been on constantly with good oil pressure. I checked with a glycerin gauge. Thanks in advance. I've named my 180 "Ol Woman ." She shares the same birth year as my wife 1967!
DougG
Posted: 09 Sep 2023 at 1:40pm |
Its the same Chevy used for the 350 back in those years
ClayP
Posted: 09 Sep 2023 at 3:27pm |
Thanks Doug!
