D17 Series IV Power Steering Belt
EPALLIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EPALLIS Quote  Post ReplyReply Direct Link To This Post Topic: D17 Series IV Power Steering Belt
    Posted: 06 Sep 2023 at 10:12pm
I noticed the power steering belt on my D17 Series IV is cracked in several places. I'm guessing I should replace this before it breaks.   Has anyone ever replaced one of these before?  Just curious on the difficulty and any past stories encountered.  As always, thanks in advance!
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2023 at 11:05pm
Only problem is it is a close fit between front pully and front support but it will go.                MACK
Macon Rounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2023 at 10:10pm
Well....
looseing the PS pump bolts can be challenging.....
and
that's how you tighten/loosen the belt.
Make sure you have quality angel wrenches on hand.
Not much turning radius on one of those bolts.
Best of luck.
Finesse not force !!!
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2023 at 2:45am
Just adjusted/ tightened my series III. no issues if the bolts are not seized!
Blue Skies and Tail Winds
                          Dana
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2023 at 6:32am
Those bolt heads are best worked on with a good quality open-end 9/16" wrench that has WIDE tangs. A cheap narrow wrench doesn't make full use of the head of the bolt, especially if the last guy used a cheap wrench and has rounded off the bolt heads a bit.
