anyone here ever build a wobble wagon? |
LouSWPA
Joined: 11 Sep 2009 Location: Clinton, Pa Points: 25548 |
Topic: anyone here ever build a wobble wagon?Posted: 04 Sep 2023 at 4:34pm |
just curious of the ways and means to achieve a reasonable/acceptable ride w/o tossing people out of the vehicle. Looking a building a parade float of a boat, and as it proceeds down the parade route, behind the tractor looks to be riding the waves.
I am still confident of this;
I will see the goodness of the Lord in the land of the living. Wait for the Lord; be strong and take heart and wait for the Lord. Ps 27 |
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5188 |
Posted: 04 Sep 2023 at 7:25pm |
Weld in one or more wheel centers off center?
Walker
Posted: 04 Sep 2023 at 8:01pm |
Get one of them Weeble sized Haveaheart traps and some sodiumpentathol.
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 90826 |
Posted: 04 Sep 2023 at 8:07pm |
I think i would do 1 or 2 wheels... not all 4.. that would get more violent movement.
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25256 |
Posted: 04 Sep 2023 at 8:17pm |
one front, one rear, opposite sides,2" lift... pack a LOT of PUKE bags.....$1 each, you'll make millions...... hay there's a silver lining in every cloud !!!!
LouSWPA
Posted: 04 Sep 2023 at 10:11pm |
LouSWPA
Posted: 04 Sep 2023 at 10:20pm |
Ya, i was thinking offset wheel centers, just dont know how many wheels and how much. Also was considering splayed axles to get a more wave like motion, rather than the up and down motion that would result from the both under center (assuming a boat trailer rather than a wagon). If I use a wagon chassis I am thinking the wheel offsets would be opposing, front to back. I guess at some point I will just need to start cutting and welding and see what happens.
tadams(OH)
Joined: 17 Sep 2009 Location: Jeromesville, O Points: 11403 |
Posted: 05 Sep 2023 at 1:47pm |
I think I would start with one wheel and add another if one wasn't enough
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42270 |
Posted: 05 Sep 2023 at 2:10pm |
The speed of tow would have a lot of effect also .
Had some wide tires on dump truck front axle that were out of round , low speed could hardly notice it but around 40 MPH got lot of up and down motion - then seemed to steady out higher speed , empty was a real ride some times , loaded it smoothed out . Seems getting wheels timed so same motion was not at same time would be another problem . Then putting centers OFF Center with a hard lean might change action also , hard on tires but what to heck all for fun |
iowallis
Joined: 04 Jun 2017 Location: North Iowa Points: 387 |
Posted: 05 Sep 2023 at 7:01pm |
Have a extra wheel underneath hidden, maybe a steel bar hinged to the rear axle and a hub at the other end for the wheel to mount on. On the other side of the extra wheel have a bar welded off center extended past the hub grease cap. Pivot another bar up to your "boat" so as your drive along it will rock the boat. Being hinged at the rear axle would allow you to lift the extra wheel up off the ground so the boat doesn't rock when traveling at higher speeds to/from the parade.
shameless dude
Posted: 06 Sep 2023 at 6:24pm |
the Shriners have them, they had someone cut the center out, and re-weld it back on just off center, don't take much.
