g262 block verses 262 diesel block
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Topic: g262 block verses 262 diesel block
    Posted: 03 Sep 2023 at 9:54pm
can the g262 block be used for a doner for a diesel 262
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2023 at 10:11pm
Same vintage for both, yes they interchange. If one is a 1958 and the other a 1962, they are not the same vintage. Water pump has to be the same style on both.
randy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2023 at 7:20am
Did that on mine. I got a block from MACK and used his fire rings in the head gasket.
Runs great
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2023 at 9:10pm
I have one set of fire rings left and there won't be any more unless my health problems change and don't think that can happen.                 MACK
Don Jr NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don Jr NY Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2023 at 4:17am
Hi Mack. I'll take those fire rings. Let me know where to send the check. Thanks. Don Jr.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2023 at 9:45pm
Did the gas version have the same issue as the diesel did?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2023 at 9:57pm
Same block. Same sleeves. No problem. LESS compression.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2023 at 10:27pm
thats kind of what i wanted to hear
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2023 at 7:14am
did exactly what you are wanting and got a great running D19 diesel
