CA Remote Hydraulic Port |
JimWenigOH
Topic: CA Remote Hydraulic PortPosted: 02 Sep 2023 at 9:23pm |
My CA has had a cap on the remote hydraulic port ever since I've had it. I need to run a remote cylinder now, and would like to know if the threads are 1/2" tapered pipe thread or are they 1/2" straight thread. Anyone know right off?
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 90908 |
Posted: 02 Sep 2023 at 10:22pm |
i dont ever recall running into a straight thread on a tractor... I think all the hydraulic fittings are taper pipe.
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4078 |
Posted: 03 Sep 2023 at 4:39pm |
are you mesureing the hole size with a tape measure ? because 3/8 or 1/4 npt seems more inline to me
sparky
Joined: 13 May 2011 Location: So. Indiana Points: 1838 |
Posted: 03 Sep 2023 at 5:09pm |
I’ve had several CA’s and 2 of them had capped outlets. I bought 2 Pioneer female couplers from Rural King and installed them and are working well after many years of service.
Edited by sparky - 03 Sep 2023 at 5:09pm |
JimWenigOH
Posted: 03 Sep 2023 at 8:21pm |
The reason I asked was that after installing the 1/2" NPTF coupler fitting, it leaked like a sieve. I've replaced many over the years without any problems at all. I replaced a worn one on my WD45 last year and if memory is correct, it used a rubber washer and back-up nut. CA Parts Catalog shows a "ring, snap, coupler nose", P/N 224872 installed behind the coupler nose. Is that an o-ring?
sparky
Posted: 03 Sep 2023 at 9:28pm |
Jim when I installed mine I just used Teflon tape. By the way I’m the guy who stopped by your place several years ago and picked up a single rear weight for a CA. Again, thanks.
