WD45 diesel wiring diagram question
Farrell(Utah) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Farrell(Utah) Quote  Post ReplyReply Direct Link To This Post Topic: WD45 diesel wiring diagram question
    Posted: 01 Sep 2023 at 10:43pm
     I was looking at the wiring on my WD45 diesel and have a question about the L terminal on the voltage regulator.  The tractor has a 12 volt generator with a four terminal voltage regulator.  Currently, the L terrminal on the voltage regulator is connected to the light switch terminal in the instrument panel.  It appears to be providing power for the lights.
    Where should the L terminal on my voltage regulator be connected in the instrument panel?  Thanks.
A(1937), 2 G, 2 WD45 diesels, 6 WD45 gas, UC, 2 WD, D17 gas, WF, Farmall 400, D12, Kubota B3030
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2023 at 8:42am
that should be correct... The "L" is just another HOT WIRE... It was a common terminal 50 years ago on some systems... normally it came from the ignition switch ... which fed the lights switch.
Here is a SIMILAR drawing... to give you an idea
Edited by steve(ill) - 02 Sep 2023 at 8:49am
Post Options Post Options   Thanks (1) Thanks(1)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2023 at 8:51am
As shown in Figure 3, the regulator has an extra terminal marked "L" which is connected with the lower contact point in the cutout relay. This extra terminal permits current from the generator to be diverted to the load  ( head lights) without its passing through the current-voltage regulator.
Edited by steve(ill) - 02 Sep 2023 at 8:52am
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2023 at 10:00pm
Thanks Steve, I never have seen that before. It also bypasses the ammeter.
ciero2003 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ciero2003 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2023 at 9:06am
I have a '51 WD with a 12V generator. Could I use this diagram in wiring a WD properly?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2023 at 9:18am
yes.... also determine if you want positive or negative ground.... but all the WIRES are the same.
if your regulator has an L terminal, you can run it to the light switch... If it does NOT have an L... just forget that part.
Edited by steve(ill) - 25 Sep 2023 at 9:21am
Post Options Post Options   Thanks (0) Thanks(0)   Quote ciero2003 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2023 at 9:22am
Thanks so much!
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2023 at 9:26am
from the above DELCO link...
This page was generated in 0.284 seconds.
