1965 Allis Chalmer FDX40-24 Detroit 2-53 Swap |
| Author | ||
A310
Joined: 30 Nov 2017 Location: Kelowna, Canada Points: 105 |
Topic: 1965 Allis Chalmer FDX40-24 Detroit 2-53 SwapPosted: 29 Aug 2023 at 9:36pm |
I restored my old Allis back to running condition just over 5 years ago. Has the Buda D175 which was really abused and in bad shape. Having said that, it now has 250 hrs on it since it's been back in service and never run better. I decided to swap it out a few years ago with a Deere or Detroit. Found an old 1958 Detroit 2-53 and rebuilt that to replace the Buda. The day has finally come to swap out the Buda for the Detroit. I'll post videos for those of you that are interested.:)
1965 AC FDX40-24
| Sponsored Links | ||
Eric B
Joined: 09 Feb 2012 Location: British Columbi Points: 1009 |
Posted: 31 Aug 2023 at 3:58pm |
Thanks for posting this project. I'm looking forward to consecutive videos. With a combined interest in A-C and Detroit engines you have my attention
A310
Posted: 31 Aug 2023 at 4:09pm |
I'm slowly making progress on the build.:) Working on the engine mounts now.:)
1965 AC FDX40-24
A310
Posted: 01 Sep 2023 at 9:22am |
Test fitting the 2-53 into Allis. It's a tight fit, but fit's pretty nice. The Detroit is 31" compared to 26" for the Buda.
1965 AC FDX40-24
A310
Posted: 01 Sep 2023 at 9:25am |
Test fitting the 2-53.:)
1965 AC FDX40-24
Eric B
Posted: 01 Sep 2023 at 11:52am |
Looking good, your skills for making modifications are amazing!!
A310
Posted: 03 Sep 2023 at 1:59pm |
Thanks.:)
1965 AC FDX40-24
A310
Posted: 20 Oct 2023 at 6:47pm |
Some more progress on the Detroit 2-53 swap.:) I've got the engine mounted and started in the Allis for the first time. Just finished up the flywheel last weekend, I joined the Buda and Detroit flywheels together and works perfect. Now working on the hydraulic pump while the flywheel is off getting balanced.:) On the home stretch now.:)https://www.youtube.com/watch?v=t-jZSlnuZCE
1965 AC FDX40-24
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55247 |
Posted: 20 Oct 2023 at 8:19pm |
Maybe its a trick of perspective, but that muffler looks mighty close to where I assume you sit.
A310
Posted: 20 Oct 2023 at 8:34pm |
It sure is.:) This is for testing only, the final intake and exhaust will be rerouted so the seat can be used.:)
1965 AC FDX40-24
A310
Posted: 29 Oct 2023 at 8:49pm |
The hydraulic pump mounts finished, so the 2-53 can go back into Allis for the last time.:)
1965 AC FDX40-24
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8978 |
Posted: 30 Oct 2023 at 7:30am |
Love 2 stroke Detroits! That little guy is cute!
Lee Bradley
Joined: 13 Oct 2009 Location: Kingston, WA Points: 120 |
Posted: 01 Nov 2023 at 12:17pm |
Have to question this project. HD-5 was unpowered with the 2-71 detriot. I would be looking for a 3-71 or 4-53 if I was going to go with a Detriot and I like the sound they make. The 3-71 in my HD-7 has a sweet sound.
CAL(KS)
Joined: 18 Sep 2009 Location: Chapman, KS Points: 3804 |
Posted: 01 Nov 2023 at 1:16pm |
Dad- WD, D17D, D19D, RT100A, 7020, 7080,7580, 2-8550's, 2-S77, HD15 |
A310
Posted: 01 Nov 2023 at 6:21pm |
I chose the 2-53 for it's size as the 2,3-71 and 3,4-53 are just too large to fit in the chassis. The 2-53 is 40HP and 120 ftlbs of torque which was what the Buda D-175 had. It's the perfect Detroit for this swap.:) |
1965 AC FDX40-24
Lee Bradley
Posted: 02 Nov 2023 at 4:57pm |
You're correct. I must have been half asleep, I thought you were working on an HD-6. Sorry.
A310
Posted: 05 Nov 2023 at 2:32pm |
For giggles, here's the 2-53 on my dyno.:)
1965 AC FDX40-24
A310
Posted: 25 Nov 2023 at 7:22pm |
Allis comes off the stands this coming week. Back in service again after the 4 month Detroit swap. Few little things to tidy up, but there's not much left to finish.:) Here's a quick video.:)https://www.youtube.com/watch?v=ztpRd6kubag
1965 AC FDX40-24
Eric B
Posted: 25 Nov 2023 at 8:49pm |
Nice job, well done!! I'm amazed that you could do this in such a tight engine room. It'll be a bit of a balancing act to keep high enough RPM to keep the Detroit happy over the long range. So much activity with forklifts in tight spaces happen with low throttle. You'll definitely be happy to climb on and turn the key as often as you need something moved or lifted
A310
Posted: 26 Nov 2023 at 10:48am |
Thanks, it sure is tight.:) A lot of challenges getting it to fit and the last piece of the puzzle it the counter weight and exhaust routing:) Looking forward to seeing how it shakes out.:)
1965 AC FDX40-24
A310
Posted: 28 Nov 2023 at 9:02pm |
What a hoot, finally got the Detroit out of the shop.:) It runs really nice, totally different than the Buda, but works as well. I'll finish up the exhaust and put the counterweight on in the coming days. Here's a video of it running around for the first time.:)
1965 AC FDX40-24
Eric B
Posted: 29 Nov 2023 at 1:09am |
That's great, pretty much mission accomplished. It's very convenient that you can wind up the RPM now and then by cruising across that big parking lot. I was always very conscious about my Detroits idling more than comfort would allow. I really appreciated how easy the Detroits would never overheat (providing everything was in order). With our hot summers it used to be common to see import excavators run with the hood open because of overheating - never a Detroit under the same conditions.
Thanks for your good video work in sharing your project with us.
DiyDave
Posted: 29 Nov 2023 at 4:29am |
A310
Posted: 29 Nov 2023 at 8:39am |
Thanks, another couple of weeks and it should be all buttoned up.:) If you like Detroit's my daily driver is a Ford F350 4-53T powered.:) Here's a video of it.:
1965 AC FDX40-24
A310
Posted: 29 Nov 2023 at 8:41am |
Lol, I've pondered swapping an Allison into something, but they are too thirsty.:)
1965 AC FDX40-24
A310
Posted: 19 Dec 2023 at 7:14pm |
Two weeks now since the Detroit swap and running great. Installing an electric fan and overflow bottle, then the counterweight and cage go back on.:)
1965 AC FDX40-24
orangeman
Posted: 20 Dec 2023 at 9:47am |
A310- A good bit of mechanical engineering work done to make this work - credit to all of your excellent knowledge in doing this!. Maybe I missed it, did you machine an adapter plate to merge the detroit to the bellhousing?
Keep up the great work! ~ Respectfully Orangeman
A310
Posted: 22 Dec 2023 at 12:14pm |
Thanks, no need for any adapters as the Buda and Detroit share the same #4 Flywheel housing, the the trans bolted on. I did however have to machine the Buda flywheel to fit inside the Detroit flywheel as I could not find a Detroit flywheel that would work. The two were machined on a firends lathe and then pressed together to form one flywheel.:)
1965 AC FDX40-24
A310
Posted: 03 Mar 2024 at 11:14am |
Update video.:) Coming up to the 19hr mark now on the Detroit swap and running great. Cobbled together a video working the little Jimmy and what it sounds like. Certainly doesn't need a backup alarm.:)
1965 AC FDX40-24
Eric B
Posted: 04 Mar 2024 at 12:40pm |
Thanks for the update, it's good to see your project being a total success. For those of us that like Detroit 2-cycle there is free music to go every time on start up
