Should I be concerned? |
Post Reply ![]() |
AC720Man ![]() Orange Level ![]() ![]() Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5244 |
![]() ![]() ![]() ![]() ![]() Posted: 28 Aug 2023 at 9:00pm |
Im putting my D17 diesel back together and as I put my belts on I noticed how close the fan blade comes to the air cleaner. The air cleaner bolts to the head so it’s not like I can move it. I guess I didn’t notice this before because the fan blade wasn’t in this position before when I took it apart. Looks like a 1/8” clearance. Anyone out there that has a series 1 diesel mind taking a glance and let me know what they see?
Alberta Phil ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: Alberta, Canada Points: 3930 |
Are all the blades showing the same clearance? Maybe a bent fan blade if they are not.
Dirt Farmer ![]() Silver Level Access ![]() Joined: 15 Sep 2020 Location: Illinois Points: 442 |
Is there an outside chance that the fan on backwards, and the offset has the blades closer to the canister.
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 88224 |
My bad Steve, I didn't spend enough time studying the photo and thinking of what way the engine rotated. Had brain fog I guess
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8648 |
If you put it back like it was it must have been that way before. Clearance means it's not touching! Lol. The blade should flex fwd in use if anything. Where's your faith?
looks like a spacer plate might be a good idea !! ..... be nice to have 1/4 inch clearance.
Ed (Ont) ![]() Orange Level ![]() ![]() Joined: 08 Nov 2009 Location: New Lowell, Ont Points: 1504 |
Does look very close. Or is it camera angle? Was there a spacer under it? Maybe was lost over the years.
Lars(wi) ![]() Orange Level Access ![]() ![]() Joined: 14 Sep 2009 Location: Permian Basin Points: 8110 |
Fan appears to on backwards. Engine rotation is clockwise if I’m not mistaken.
RickSoKansas ![]() Bronze Level ![]() Joined: 09 Dec 2021 Location: Arkansas City, Points: 13 |
The picture looks like mine, about the same clearance between the fan and the air cleaner, the fan is the same as mine. Been that way for years. Rick
D17 Diesel
Thanks Rick for looking at yours. I did verify all blades are the same gap when I rotated the fan. So, I will feel better knowing it is correct.
Appreciate everyone for their input. Rob |
After a few months of being dismantled for repairs, new paint, new wiring harness, pump work, I fired her back up yesterday. No issue at the clearance of the fan and breather. Fan ran straight and true. Just really surprised at how close it is and that I did not notice it before.
Post Reply ![]() |
