CA vs C |
Post Reply ![]() |
ACinSC ![]() Orange Level ![]() Joined: 16 Dec 2015 Location: South Carolina Points: 3034 |
![]() ![]() ![]() ![]() ![]() Posted: 28 Aug 2023 at 4:23pm |
What's the difference between the two? One's a 3 speed and one's a 4 ? Just wondering. Thanks
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 88256 |
CA is a 4 speed, spin out rear wheels , better hydraulic pump , slightly heavier rear axle housings...........
basically same engine , radiator, sheetmetal, tires... CA is a "newer model" of the C. a lot of the parts can be installed between the two as assemblies.
Edited by steve(ill) - 28 Aug 2023 at 4:38pm |
DiyDave ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54295 |
Don't forget the CA has pto that will spin while the tractor slows or stops. Not exactly live pto, but much improved over the C...
Thanks Steve and Dave
I see both on marketplace pretty often. |
as DAVE said, the CA has a hand clutch on one rear axle to disengage travel while maintaining the main clutch drive thru to the PTO shaft... Thats an advantage... but 90% of the ones you buy WILL NOT WORK after 60 years... Most need rebuilt.
Les Kerf ![]() Orange Level ![]() Joined: 08 May 2020 Location: Idaho Points: 1345 |
If your agility has diminished such as mine has, the C (and B) with the flat seat and backrest is fairly difficult to mount and dismount; the CA has a pan seat without the back rest and is somewhat easier for the aged and infirm
![]() Edited by Les Kerf - 28 Aug 2023 at 6:34pm |
I hear ya , Les . My old D 15 is easy to climb up on . Especially with the nice step I bought from the guy on this site . Thanks !
Dale (Stonelick) ![]() Bronze Level ![]() ![]() Joined: 13 Jun 2019 Location: Stonelick, Ohio Points: 185 |
I think of 10 improvements (1) HP, (2) hydraulics, (3) 4 speed trans, (4) heavier axle, (5) draft control, (6) seat shock, (7) hitch, (8) hand clutch [Rick rebuilt mine], (9) live PTO, and (10) spin out rear wheels.
1951 CA - 1944 C - 1949 B - Kubota M6800
dfwallis ![]() Orange Level ![]() Joined: 09 Mar 2023 Location: DFW Points: 854 |
CA also has an increase in horsepower of about 11% over the C. They increased the compression ratio to 6.25:1 and increased the max RPM (don't know what else). This in part to enable support for a 2-bottom plow.
Gary , that was part of my confusion . I thought they were both 18 HP ? Thanks
Higher compression pistons and different governor spring to increase the RPM.
After 70 years, most of them have probably been rebuilt with an "overbore" kit. That can further increase HP from about 26 stock to about 29, nearly equal to a stock WD.
Thanks guys.
Lars(wi) ![]() Orange Level Access ![]() ![]() Joined: 14 Sep 2009 Location: Permian Basin Points: 8115 |
My Father said the CA was the perfect tractor for the Roto-Baler. Just enough hp to notice the engine sound change as the hay condition changed during the day. Dad said a trained ear would know when the baler needed adjustment, by listening to the engine.
sparky ![]() Orange Level Access ![]() ![]() Joined: 13 May 2011 Location: So. Indiana Points: 1787 |
I’ve owned 7 CA’s and have 3 now. Just my opinion but pound for pound I believe that the CA’s were the strongest tractors Allis ever built.
Post Reply ![]() |
