idiot engineers
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Topic: idiot engineers
    Posted: 26 Aug 2023 at 5:53pm
yes, dash of friends new car....
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2023 at 5:56pm
Should be a way to change that
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2023 at 6:33pm
shouldn't HAVE to !!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2023 at 6:38pm
what kinda car?
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2023 at 6:42pm
Your friend is German? Or your friend imported a German car? Friend if mine has a GM pickup. There is a button to switch from metric to US
Red Bank View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Red Bank Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2023 at 8:57pm
The 186 mph speedometer?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2023 at 9:02pm
here in Canada we're forced to use Metric, except when the cops are looking for bad guys...
read the speedo numbers again......
I'll ask him what his new ride his...he just had staples yanked out of his back so not mobile...
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2023 at 9:09pm
I'm seeing a 300kph speedo. Translates to 186mph
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2023 at 9:18pm
hint: Read aloud the NUMBERS, from 0,20,40,.....
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2023 at 6:01am
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2023 at 6:06am
The font makes it look like it says 80 twice instead of 60? Or it outright says 80 twice?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2023 at 6:08am
Probably more like idiot “designer” or programmer!
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2023 at 6:41am
OK, look at the speedo 'scale' and get the pointer up to say 115KmH
I used to design meters for equipment for decades and never ,ever saw a 'split, linear' scale.
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2023 at 6:50am
So what you are saying is that after 100 it goes in 40 increments instead of 20 and the visual space is the same? My truck was a Canadien lease return and the speedo by default was kilometers. Push a button and went to miles. Drove me nuts but Ford said it was right according to where it was sold. Finally had to remove 2 computers and have the default changed to miles.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2023 at 8:08am
changing the linearity of the gauge is not as big a problem as doing it right at 60- 65 mph... You could be 10- 15 mph off when the COP sees you..  Hopefully the digital readout is correct !!
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2023 at 9:53am
Gonna be a lot more "drivers" (steering wheel holders) of these totally unaware of what's going on out front as they will be looking at the screens instead of thru the windshield!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2023 at 11:20am
Oh the humanity!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2023 at 12:24pm
just found out , it's an AUDI S5..... supposedly speed limited to 250KMh , Cdn regulation.
im4racin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2023 at 12:28pm
I’m not sure what the talk is all about. It’s a computer rendered gauge so spacing is irrelevant to accuracy in the ways of an old mechanical version.  That space change is entered into the code for that display.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2023 at 12:44pm
You must not read much of Jay.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2023 at 12:57pm
Paul-Buh will be next.
Darwin W. Kurtz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darwin W. Kurtz Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2023 at 2:05pm
Well, shouldn't the gage be accurate......if you think you are going 20 you shouldn't be going 30....who cares if the computer is what's accurate, if you are watching the stupid gage. Why even have the gage if you're not supposed to watch it
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2023 at 7:30am
exactly... the PROBLEM is when you hit 100 kph, the NEXT 40 are random or useless.. The digital readout might be right, but HOW do you read the gauge ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2023 at 8:59am
The German Autobahn has a “recommended speed limit” of 130kmh(80mph) in it’s restricted areas. There is no speed recommendation in it’s non-restricted areas. So if you’re a speed enthusiast, the higher velocity becomes more of a feel than a number. Matt Damon, portraying Carol Shelby in the movie Ford vs Ferrari, speaks about “fluidity at about 7 grand.” At 7000 rpms, the human body becomes a harmony/balance in motion. I’m probably not quoting Matt’s exact movie quote, but you get the idea…
Most of Europe’s motorways have 130kmh limits. So the Audi’s 140kmh speedometer setting has logic for Europe.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2023 at 11:00am
hmm, 140 is only HALF of the full scale deflection of the gauge though.
have heard cars are limited to 240KMh, motorcycles from Japan 299KMh
This page was generated in 0.313 seconds.
