WHAT ARE DUAL'S WORTH?
SIMPLICITY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SIMPLICITY Quote  Post ReplyReply Direct Link To This Post Topic: WHAT ARE DUAL'S WORTH?
    Posted: 19 Oct 2010 at 8:57pm
HELLO
 I AM LOOKING AT A SET OF MEXICAN HAT DUAL HUBS AND WEDGES TO PUT ON A 7060 ANY IDEA WHAT THEY ARE WORTH? WILL NEED PAINT HAS NO RIMS
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2010 at 5:22am
I bought a pair of Mexician Hat duals with rims at an auction last month for $150. He was asking $400 for them a year before the auction. I'm told that both prices were a good deal. I'm planning to use the duals on my 220.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2010 at 5:56am
I see them go from $150 to $250 at auctions pretty regular and sometimes less.
Wink
I am a Russian Bot
Dale Hardtke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale Hardtke Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2010 at 9:12am
I think we have some confusion about the term mexican hat dual hubs. According to Swinford, Mex. Hats are the 350# casting that axle mounts with six bolt wedges and provides an outside Dia.to hold 38" double bevel rims with 16 clamps, or power adjust rims with 8 clamps.  NOT the lighter 120# castings that bolt to the six bolt 16" Dia. bolt pattern on the inner wheel casting and provide a nine hole hub to mount a 34" die formed outter wheel rim. Mex. Hat's were first made to be used on 220/210 tractors and later carried over into the 7000 series.  I would think that they would work on any AC tractor W/six bolt wheel wedges and enough axle length. I'm thinking there is some confusion based on the prices given for the Mex. Hat dual castings.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2010 at 9:57am
Yep, I was confused. So I have no idea but I wish I had a set of "mexican hat" duals.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2010 at 10:02am
The duals that I bought were the heavy 38" with the 350# cast centers and double wedges that Dale mentioned. I have the smaller 34" set with the 9 both pattern for pressed steel rim duals on my D-21. What is the correct terminalogy or name for each?
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2010 at 10:47am
here is a picture but kinda hard to see. So these ar NOT mexican hats?
Dual mounts
And these would be Mexican Hats"
Daul mounts
Edited by Matt MN - 20 Oct 2010 at 10:52am
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2010 at 12:18pm
Neither of those are mexican hat duals, the bottom looks like a long axle tractor with 2 standard cast centers.  Mexican hat duals are like the standard cast centers, but just imagine the center of them being "punched" so that it is offset.  I tried to find a picture on google, but couldn't find any in my quick search.
Hurst
1979 Allis Chalmers 7000
5800 Hours
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale Hardtke Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2010 at 9:19pm
Hurst:  You got it correct.
