Correct hyd. Fluid 715 backhoe |
bleeds orange
Joined: 11 Sep 2012 Location: mt. vision, ny Points: 707 |
Topic: Correct hyd. Fluid 715 backhoePosted: 22 Aug 2023 at 8:05pm |
Is it ok to use the same hydraulic fluid as the stuff compatible to the 821 allis-chalmers hydraulic/transmission fluid that is used in my bigger 7000 series allis-chalmers tractors?
I'm not sure on correct hydraulic fluid for my 715 allis backhoe. Thanks cory |
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42246 |
Posted: 22 Aug 2023 at 11:16pm |
Hyd Fluid - I use AW fluid m now the heavier grade 42 and if I have to add any later in year will go to the AW 32 .
As the rear differential is made by FORD and has wet brakes , Universal Tractor Fluid , or equivalent used there , |
bleeds orange
Posted: 23 Aug 2023 at 7:09am |
Is it ok if I have the stated hydraulic/transmission fluid in backhoe or should it be changed out?
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 90538 |
Posted: 23 Aug 2023 at 9:41am |
we use UTF in our CASE 530 hoe.... I dont see anything MAGIC about the 715 that would require other..
bleeds orange
Posted: 23 Aug 2023 at 1:37pm |
Coke-in-MN
Posted: 24 Aug 2023 at 11:59am |
Any oil should work as long as it's anti foam , anti wear additives . In fact a 10/30 engine oil will work . In my HD5G I got a couple drums of ATF that I used for the hydraulics and it worked fine for years of use .
It's more important to check for moisture content in the oil no matter what section of the unit uses oil. |
bleeds orange
Posted: 28 Aug 2023 at 1:47am |
Thank you.
