28” Rim Rail Differences
KenBWisc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KenBWisc Quote  Post ReplyReply Direct Link To This Post Topic: 28” Rim Rail Differences
    Posted: 22 Aug 2023 at 3:11pm
I picked up a new 14” x 28” rim on an auction to replace one on my 45. However, the rails are closer together than on my other rims. Can it be used?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2023 at 6:32pm
I've seen 10 inch, 11 inch, 12 inch, 13 inch and 16 inch rims that accept a 28 inch tire for an A-C tractor.  So, on any of those factory A-C rims if you measure from the top of one rail directly across the center to another rail you would have about 23 or 24 inches , right???   That's the dimension you MUST have within 1/4" I'd say.
Darb210 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darb210 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2023 at 7:21pm
my guess is you bought a 26" rim
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darb210 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2023 at 7:24pm
13x26 measured at the outside edges is 14x28.  measure inside the bead at both points.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KenBWisc Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2023 at 4:31pm
I rechecked my measurements. It is a 14 x 28 measured from inside the beads. The distance between the rail ends is 13”. My concern is the distance between the rails which is less than on my other rims. They also looked like they are at a different angle. We’re Oliver adjustables different from Allis?
