7080 Alis Chalmers
Braylen Bruns View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Braylen Bruns Quote  Post ReplyReply Direct Link To This Post Topic: 7080 Alis Chalmers
    Posted: 19 Aug 2023 at 8:07pm
When you just start the tractor it does not go into gear unless you fight it and force into the gear you want. But after a while when it gets hot it shifts great and there's no problems. Does anyone know what this may be.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2023 at 8:29pm
Clutch cable needs adjusted and new bushings in pivot. With engine shut off, take all free play out of clutch pedal, after replacing bushings.                     MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Braylen Bruns Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2023 at 8:38pm
Ok I will get that all done I will let you guys know if it will work.
