Tips for pulling the head (160) |
Post Reply ![]() |
Fellenz ![]() Silver Level ![]() Joined: 22 Mar 2010 Location: Phelps, NY Points: 148 |
![]() ![]() ![]() ![]() ![]() Posted: 19 Oct 2010 at 5:03pm |
Hello,
I'm pulling the head to troubleshoot engine problems on this tractor. Following the I&T book it appears I have done everything necessary to prepare the head for removal. I have removed all the necessary lines, removed all the head nuts, etc. I tried to pick it with an engine crane and a sling but it seems to be stuck pretty well and I didn't want to put too much force on it until I consulted the experts for advice. This is my first time doing any major work on a diesel engine so I'm unsure what exactly I should be expecting. Advice? Thanks, Erik |
kip in cny ![]() Orange Level ![]() Joined: 29 Nov 2009 Location: Jordan NY Points: 538 |
did you pull the studs if your not picking up 100% stright they will pinch and be a pain.
160 CA 920diesel 5020 HD-3
No I did not pull the studs, what would be the best method for pulling them out? Thanks! |
a stud remover or 2 nuts jamed together. If you dont have the puller dont mess with them mainly due to you will have to torque them back into place.
injpumpEd ![]() Orange Level Access ![]() ![]() Joined: 13 Sep 2009 Location: Walnut IL Points: 4960 |
dont pull the studs, you just need to break the gasket loose. creative use with a prybar will release it. good luck.
Bob D. (La) ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Louisiana Points: 25529 |
I always use a short (12") or so length of 2X4 and a hammer to break loose heads that are stuck. Use it in several places around the head and it will free it up . HTH God Bless.
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 20983 |
Remove the injectors from the head before removing if it is a direct injection style.
Thanks everyone for the advice. I'll grab a small prybar and give it a go.
Thanks, Erik |
Yea, I remember he already had the injectors out. Excellent point though Dr.
Post Reply ![]() |
