Alis Chalmer 200
Braylen Bruns View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Braylen Bruns Quote  Post ReplyReply Direct Link To This Post Topic: Alis Chalmer 200
    Posted: 19 Aug 2023 at 2:13pm
My Alis Chalmers had a injector pump problem we fixed it and now there is alot of white smoke blowing out of it and a abnormal knocking when you run it wide open.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2023 at 2:27pm
Check the timing,, easy to do,,
Post Options Post Options   Thanks (0) Thanks(0)   Quote Braylen Bruns Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2023 at 7:41pm
Me and my dad went through that but we may of got it a click off or something. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2023 at 8:40pm
Always rotate engine in direction of rotation to check timing. If you go past Mark, turn back at lest 20 degrees and up again.               MACK
This page was generated in 0.087 seconds.
