D 15 series 2?
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Topic: D 15 series 2?
    Posted: 18 Aug 2023 at 4:01pm
Were they 12 volt negative or positive ground?  My own fault, robbed the battery for another and don't remember.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2023 at 5:15pm
From the factory with a generator??.....POSITIVE ground.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2023 at 6:38am
You can check to see what it was before you removed the battery. A lot of them were changed from original positive ground to negative ground.
If the wire going from the coil to the distributer is attached (through the switch) to the negative terminal, it is (as original) positive ground. If it has been changed to negative ground, the wire going to the distributer will positive pole of the battery.
Changing from positive ground to negative ground is very easy. Just change the wires on the coil (so the opposite polarity is going to the distributer) and "flash" the generator.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2023 at 11:39am
It was converted to alternator, I am still confused, the negative from the coil goes to the distributer, does that tell you anything?
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2023 at 5:46am
Yes. It tells us the ignition system is set up NEG ground
General rule of thumb-if you see an alternator its negative ground.
Be careful with that rule, because an alternator can be taken apart and made to charge POS ground, however out of the box they are set up to charge NEG ground
Generators will charge either without changing any parts, just have to reflash the VR
Starters do not care
1968 D15D,1962 D19D
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2023 at 11:03am
another quick tip: the positive and negative post on a battery are different sizes.
unless someone changed the cable ends or put cheap bolt on cable ends, the negative is smaller than the positive.
Dan
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF
D15 SER.2 DIESEL
D12 SER.I, D10 Ser.II
2-720'S D21 Ser. II
Gmc,caterpillar
