7020 Torque Specs
Jack(Ky) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack(Ky) Quote  Post ReplyReply Direct Link To This Post Topic: 7020 Torque Specs
    Posted: 17 Aug 2023 at 5:29pm
Anybody have the torque specs for the rods and mains on a black belly 7020. Thanks
'59 D14 '68 170 Diesel '81 7020 40 All Crop
nowaktj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nowaktj Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2025 at 1:05pm
This is what the service manual states but is it accurate?   I am also working on a 7020 engine (Out of a M2 combine).
Edited by nowaktj - 24 Sep 2025 at 1:06pm
D19D, D17D, WD, WC, Snobee, #83 Plow, SC Blade, 14' disk, 400 series planter, B , Terra Tiger, M Dozer w/Baker Blade, TL-12, 42S Grader, G
Post Options Post Options   Thanks (0) Thanks(0)   Quote nowaktj Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2025 at 1:12pm
I bought new rod bolts from AGCO.   I looked at the head of the bolts and they are stamped with "EMP" and "170M".
Here is a post I found from 2015:   301CI allis motor model 649T - AllisChalmers Forum
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2025 at 1:41pm
80-85 ft lbs for 301 rod bolts is toooo much !!   Must be an I & T book ??   45 ft lbs is A-C spec.
Edited by DrAllis - 24 Sep 2025 at 8:26pm
joe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote joe Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2025 at 12:06pm
AGCO shop manual states the main bearing cap as being a Grade 8 bolt to be torqued to 135 ft lbs.
The conn rod bolts are 3/8-24 , Grade 100, torqued to 45 ft lbs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote nowaktj Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2025 at 11:30am
This engine, out of a M2 combine, I plan on putting into a 7020.   I noticed excessive crank end play so pulled the pan to discover the clutch side of the #4 bearing has the shoulder wiped off of it.
What would have caused this?   I plan on putting in new main bearings but if the crank is cut wrong or ??, I don't want to throw my money away.
