WD45 ignition coil |
Post Reply ![]() |
Driverdan ![]() Bronze Level ![]() ![]() Joined: 21 Feb 2015 Location: Owego,NY Points: 175 |
![]() ![]() ![]() ![]() ![]() Posted: 16 Aug 2023 at 11:01am |
Spreading manure Monday with one of my 45's and it started missing. Sounded like on of those green things when I got home! After lunch I went to swap it out with my other 45, but no start. Power all the way to distributer with key on. Put in a premium tuneup kit from Steiner (made in Taiwan package said). No help. Swapping coil for a spare. Now here is the question- coil on the tractor (which had been running for years) had distributor post wired to ignition wire, and battery post wired to distributor .?.? This would seem to be backward to me..do I hook it up like the old one that worked or hook it up properly?? Or doesn't it matter ?? Thank you guys..(considered scrap gas, drained tank, sediment bowl, and carb bowl then put in fresh gas - no help).Dan
Leon n/c AR. ![]() Bronze Level ![]() ![]() Joined: 19 Mar 2013 Location: Heber Springs A Points: 175 |
If electrical system is positive ground that is right. Leon
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 88406 |
If your BATTERY is Negative HOT -- then you connect to the NEGATIVE terminal on the coil.. If you BATTERY is Positive HOT ( neg ground)-- then you connect to the POSITIVE terminal on the coil.
Thank you guys..let me give that a go !!
Post Reply ![]() |
