8000 series power director questions |
gleaner1
Topic: 8000 series power director questionsPosted: 10 Aug 2023 at 4:48pm |
Finally joined the 8000 series club.
8050 , with power director bought over the phone and low and behold the hi low pwr shift doesn’t work. Im used to the buttons on the floor. I’m assuming I should start diagnosing at the switch, solenoid, valve body? Im not sure how these style are set up. Any advise before I start tearing into it? And of course no service records or books came with the tractor. Thanks |
ALLIS CHALMERS "The color is orange"
DrAllis
Posted: 10 Aug 2023 at 5:16pm |
Make sure the clutch pedal comes clear UP. Hook your toe under it and pull it fully UP. Could be a bad switch on the clutch pedal too, which does the same thing.
Amos
Posted: 10 Aug 2023 at 8:30pm |
Check the fuse if Dr's procedure doesn't cure it
MACK
Posted: 10 Aug 2023 at 9:03pm |
8050 should have the PD switch on steering column not buttons on floor. MACK
Ron(AB)
Posted: 10 Aug 2023 at 11:40pm |
I'd start with the clutch pedal switches too.
405, 7000, 7050, 8050, 8070, L3, 2300 & 2600 disk
gleaner1
Posted: 11 Aug 2023 at 5:44am |
Thanks guys. I pulled two panels off the dash, the upper switch must have vibrated up wasn’t even near making contact. The bottom safety one i literally had to stand with all my weight to start it so that one is getting adjusted as well. I’ll try it out tomorrow. Fingers crossed that i have a good pwr director.
Any clutch cable adjustment i should do while under there? I have no specs to go from. Thanks |
NEVER green
Posted: 11 Aug 2023 at 8:47pm |
The wires on my 8050 fall off the magnetic actuator easily behind the power director valve behind the battery.
2-8050 1-7080 6080 D-19 modelE & A 7040 R50
