distributer d17 series 1
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Topic: distributer d17 series 1
    Posted: 10 Aug 2023 at 10:34am
will i be able to use the govenor and the distributer and the lube system in the wd block i am going to go get a tractor with a rod hanging out the pan on saturday  hopefully the head will be good, (rebiuldable) for the puller engine
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2023 at 8:15pm
It will all fit, but be concerned about gear lash being too tight or too loose. That is why there is an alignment pin drilled into the block mounting surface.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2023 at 10:14pm
got it home tonight looks like i will still need to find a distributer drive this has the steering pump in between iwont be useing thaton the 37 wc
