D17 oil pan gasket
Orangeinwisco View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orangeinwisco Quote  Post ReplyReply Direct Link To This Post Topic: D17 oil pan gasket
    Posted: 03 Aug 2023 at 7:17pm
Probably a dead horse here. I've done WD/45 gaskets in frame. Would it be the same or easier to pull the engine instead of the front axle? I can get a cherry picker and have engine stands.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2023 at 8:11pm
Pull front support and axel..               MACK
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2023 at 1:19am
I've put them on my engine stand and turn it upside down. It's still a fight to get the cork ends pushed into place and get pan on.
 Only ones I've done were getting sleeve O rings or new Piston/sleeves so wanted block washed & cleaned.
 I've had guys tell me it can be done in tractor but have never seen it done that way.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2023 at 3:30am
Wrap the arch gaskets in a circle (so the ends touch) and place inside of a piston ring compressor around a can or tube the correct diameter for several days to make them take shape. Glue the pan side gaskets with high tack or weather strip glue to the block and let them cure making sure they are glued well 100% everywhere. Place the arch gaskets on the pan ends with the metal clips provided. Rub a thin layer of RTV all over the side gaskets and the inside of the arch gaskets with a dab on each of the four corners and assemble. Tighten all pan bolts in several steps slowly to get everything to squeeze together. Never had to redo one since 1975.
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2023 at 5:58am
You can't pull the engine on a D17 without taking the frame rails off.  I'm not sure you can drop the pan on a wide front with power steering without pulling the axle off first.
AaronSEIA
