Wanted to buy WD-9 loader brackets
Nightman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nightman Quote  Post ReplyReply Direct Link To This Post Topic: Wanted to buy WD-9 loader brackets
    Posted: 03 Aug 2023 at 6:16pm
I am still looking for mounting brackets for WD-9 loader.  Round pipe fasten to frame with J-bolts.  Eastern South Dakota will travel.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2023 at 5:23am
It's actually a flat plate that gets clamped to the tractor side rail with 4 'J' hooks on each side.
You can easily fabricate new J hooks from an appropriate size and length bolt.
Just cut the head off of the bolt, then heat and bend the non-threaded end in to a 'U' shape.
See the attached Video at time 2:05
G
https://www.youtube.com/watch?v=jb53B1GIl0s
daveingreenbay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote daveingreenbay Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2023 at 4:20pm
If anyone is looking for the loader mounting bracketd for an Allis Ca, I may be able to help out with those.  Dave at 920 371-6666
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2023 at 5:55pm
   I Should have them....And I am coming to Redfield....You close?  Or you can grab my load and I will give them too you...Shocked   Thanks...Dale
KenBWisc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KenBWisc Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2023 at 2:21pm
I have a set in Northwestern Wisconsin.
This page was generated in 0.440 seconds.
