TSX 464 carb
Rod in MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rod in MN Quote  Post ReplyReply Direct Link To This Post Topic: TSX 464 carb
    Posted: 18 Oct 2010 at 10:35pm
HI I have a TSX Marvel Schebler Carb the Maine load adj on the Bottom of carb will not tighten up tryed a new load adj It seams like the threads are rusted way some.Has any body try to fix the threads . It looks like it only gets about two threads or so in.aaaa aany ideas on how to fix it . Do not want buy a differnt bowl . any help would be very Helpfull
 Thank You Rod In MN
wkpoor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkpoor Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2010 at 12:23am
Helicoil it. Will be better than new. They are a little pricey but do work well. Maybe take it to a machine shop where they can do it if you don't feel comfortable doing it yourself. Veery common practice to repair damaged threads. Helicoils are often installed on new equipement also to encrease durability.
