Hydraulic hose placement |
Jhilton69
Joined: 01 Aug 2023 Location: Lyerly Georgia Points: 86 |
Topic: Hydraulic hose placementPosted: 01 Aug 2023 at 9:40pm |
I blew a hydraulic hose on my AC 1962 HD6G last week and somehow got 2 of them backwards. Can someone help me get them the right way. It's the left side of the loader(driverside). There the ones that are located on the bottom back under the seat. Pics and which ones go where would help a lot. Thank ya
doctorcorey
Joined: 17 Jul 2011 Location: S. KC Missouri Points: 589 |
Posted: 01 Aug 2023 at 10:41pm |
Semper Fi USMC 1958 HD6G, 1959 MF 203 loader, 1960 Case 420B Backhoe, MF 65 Tractor/Loader Diesel
Jhilton69
Posted: 01 Aug 2023 at 11:03pm |
I reconnected them back under the seat where it has 2 stacked on top each other
doctorcorey
Posted: 01 Aug 2023 at 11:53pm |
I can't look at mine until tomorrow. There are tw0 different setups, a break at about serial number 11000, and the diagrams in the parts manual are difficult to visualize, with all the pipes stacked and running so close together.
Codger
Posted: 02 Aug 2023 at 5:23am |
Not knowing serial number of tractor limits accuracy but here is a diagram of an HD6G which may help: |
That's All Folks!
doctorcorey
Posted: 02 Aug 2023 at 7:51am |
The hydraulic fluid tank diagram shows these ports pretty well, but I can't get pictures to load here. Looking from the outside, the upper right of the 4 ports is the retract tube of the left dump cylinder, the lower right port is the dump port for the left dump cyl. Upper left port is for the boom cylinder raise, and the lower left port is for the boom cyl lower (retract).
Jhilton69
Posted: 02 Aug 2023 at 4:20pm |
Thank you this gives me a good idea where to start. Glad you could follow the lines I tried several times and got lost when they hit the connection in the middle.
Jhilton69
Posted: 02 Aug 2023 at 4:22pm |
It's a 1962 model the places it says the serial number is it worn off
Jhilton69
Posted: 02 Aug 2023 at 6:01pm |
![]() ![]() ![]() These are the 2 plates that's supposed to have the serial numbers I see 1 of the numbers looks like it's on both plates. Is this the serial number |
doctorcorey
Posted: 02 Aug 2023 at 8:42pm |
Jhilton69
Posted: 02 Aug 2023 at 11:57pm |
Thank ya
Bob_T
Posted: 20 Nov 2025 at 11:23pm |
I did the same darn thing. In a hurry, I didn't mark them because I thought they'd only fit and connect one way. Wrong! The image won't load but I'll
see what I can do using doctorcorey's text description. Thank you!
