TL-12 brake system
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Topic: TL-12 brake system
    Posted: 01 Aug 2023 at 7:48am
Hey folks,  I have my Tl-12 repower moving and driving.  Got a new master cylinder but the wheel cylinders are leaking.  Has anyone ever replaced these with a truck cylinder or another option?  I have the oem cylinder part # 3014527 and come up with nothing online.  There is a rebuild kit written in by hand in my parts book # 73014582.  Minnpar shows its a good number but backordered.  It is also a CNH construction # but shows unavailable.    Any trucks use rockwell axles from the 50's? I was hoping to come up with something before tearing it apart and have it set a long time as i have been using the loader.  These are a full floater axle so you have to pull the shaft and then the hub and bearings.  Maybe I will have to be the guinea pig and retro fit something, but im looking for a solution first.  Can wheel cylinder seals be ordered by size anywhere?
thanks
Edited by CAL(KS) - 01 Aug 2023 at 7:54am
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2023 at 9:22am
I contacted minnpar and they will have the seal kits in 3-4 weeks after i order them so I guess they order them from china?  it is what it is i guess
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2023 at 10:47pm
my 545B has truck wheel cylinders. Don't remember what they were. Did some size comparisons online to come up with it. They used what was commonly available in the day not some special one off just for them. I got them through rockauto.com for MUCH LESS than minn-parr.
nowaktj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nowaktj Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2024 at 5:08pm
I've got the non-bug eyed version of the TL 12.
  • I used Drum Brake Wheel Cylinder (raybestos.com) Raybestos WC37317 Wheel Cylinder $36 at Rock Auto
  • I was missing several plungers (wheel cylinder links).   Their part number is 753-9270 on military truck websites.
  • I had a broken return spring.  Its part number is 741-1017.   Again, available on military truck websites.
  • Thinking of replacing the linings on my brake shoes.   I think this is the right number:   752-1788.   (Eastern Surplus and Equipment)
Edited by nowaktj - 21 Sep 2024 at 3:21pm
D19D, D17D, WD, WC, Snobee, #83 Plow, SC Blade, 14' disk, 400 series planter, B , Terra Tiger, M Dozer w/Baker Blade, TL-12, 42S Grader, G
