carb for h3
lost in h3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lost in h3 Quote  Post ReplyReply Direct Link To This Post Topic: carb for h3
    Posted: 30 Jul 2023 at 9:44pm
Purchased a zenith replacement carburator for my h3. Have been trying for a week to get the carb and govenor set right to no avail. Paid a lot for the caburator which seems to run good on its own but hooked up to govenor no work. Should I try rebuilding the old marvel scheber which is an odd number. I've yet to find a kit for it.
PaDon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaDon Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2023 at 9:52pm
I also have an H3, a '61 model. I took the Marvel Schebler off and tried cleaning it but couldn't get it to run so I ordered a replacement from Steiner and got a New Zenith. I haven't put it on yet, I'm going to drill out the Zenith manifold bolt holes to match the Schebler, so I'm interested to know what you find out. Good luck, I'll be watching your thread.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaDon Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2023 at 9:55pm
Also, I ordered a rebuild kit for the Marvel Schebler from Steiner but the main jet was different in the kit they sent. I wasn't going to piece it together so ordered the replacement carburetor.
doctorcorey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote doctorcorey Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2023 at 10:23pm
Could you please explain what you mean by  'runs good' until governor is hooked up. Do you mean it idles good, but won't provide power when you load it?
Semper Fi USMC    1958 HD6G, 1959 MF 203 loader, 1960 Case 420B Backhoe, MF 65 Tractor/Loader Diesel
Post Options Post Options   Thanks (0) Thanks(0)   Quote lost in h3 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2023 at 10:39pm
runs good at idel and respones well to wide open but hooked up to govenor  will not idel
Post Options Post Options   Thanks (0) Thanks(0)   Quote doctorcorey Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2023 at 9:05pm
Whatever it is, it's probably not a carburetor problem. Maybe linkage or carb throttle bellcrank misadjusted or in wrong position on throttle shaft. Bad governor?
Post Options Post Options   Thanks (0) Thanks(0)   Quote doctorcorey Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2023 at 9:06pm
   BTW, what part of Missouri are you in?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2023 at 10:00pm
If this is a "universal" carb, the throttle shaft and its lever are adjustable ?? I think you need to synchronize the governor to the carb.     ENGINE OFF. Hand throttle wide open. Disconnect the carb to governor arm link rod above the generator. The length of this link rod should be such that it will easily slide right back into the hole on the governor arm. Do whatever it takes to make a fully open throttle butterfly link rod to slip right into a fully open governor arm. Understand ?? It is basic governor to carburetor synching.
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2023 at 11:27pm
H3 Governor:
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2023 at 6:04am
Do NOT try and bend that governor cross arm !!!  The link rod itself has enough kinks and bends in it that can be straightened to get the length you may need. A universal fit carb should have the throttle shaft lever adjustable, not needing to change the engines parts to synch it. For a novice to try and bend that cross arm can turn out badly. Don't do it. I've never had to bend a cross arm in 50 yrs. Always changed the link rod length.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaDon Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2023 at 9:44am
Excellent, thank you. I have a new exhaust manifold and new Zenith carb to put together on mine, this is great information.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lost in h3 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2023 at 2:34pm
Best info I've had. Going to try again.
Lost in H3
Post Options Post Options   Thanks (0) Thanks(0)   Quote lost in h3 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2023 at 2:40pm
doctorcorey
i'm located in north lincoln county missouri
Post Options Post Options   Thanks (0) Thanks(0)   Quote doctorcorey Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2023 at 2:51pm
doctorcorey
I owned a 80 acre ranch south of Cole Camp for the last 30 years. Still go down there occasionally to Zimmerman's Tractor for parts for my 6G.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lost in h3 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2023 at 10:22pm
Still trying to get the zenith carb. syc. with the governor. Opened up governor and carefully checked everything. Nothing wrong with it. Checked all rod linkage and everything ok. I've got to the point where I understand how and why governor works. The problem is the rod from carb is just not long enough to properly reach the cross rod and the carb linkage is not flexible enough to make it happen. I'm going to cut rod from carburetor in two pieces and make it adjustable for length. Tired of bending rod.
lost in h3
This page was generated in 0.285 seconds.
