DT 160 power take off
Tannerhett45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tannerhett45 Quote  Post ReplyReply Direct Link To This Post Topic: DT 160 power take off
    Posted: 30 Jul 2023 at 4:06pm
I have a 2000 DT 160 agco and I will be baling hay and the pto will shut off and you have to turn everything off once or a couple of time and the tractor will go back to baling just fine and other time you have to leave and let it sit over night and then it will let you bale again. It also pops up the error code e90 and I can’t seem to find that anywhere where it talks about pto being the problem. Was wondering if anyone else has had this problem. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2023 at 8:23pm
Sounds like PTO clutch is slipping. If PTO slipes a certain % it will shut it's self to protect it's self. Just another computer problem that bailing wire won't fix anymore.                             MACK
