WD45 lights |
Driverdan
Topic: WD45 lightsPosted: 28 Jul 2023 at 7:11pm |
This question may show my ignorance, but I must ask....I have the WD45 my late dad bought new in 1955. (I am on the same farm, so it has lived here all its life). Back in the 1960's the dealer put in an 8volt battery because dad thought it started too hard in winter.it was always replaced with an 8volt when a new battery was needed. Here comes the question.. The dealer disconnected the lights because he said 8 volts would burn out the 6 volt lights. Is this true ?? We have used this tractor in daytime only for 60 years...if the lights would work, it would be kinda nice to hook them up... Or if not, are there 8 volt bulbs? (This is a working farm tractor, not a show tractor)....thank you...Dan
Dusty MI
Joined: 13 Sep 2009 Location: Charlotte, Mi Points: 5060 |
Posted: 28 Jul 2023 at 7:42pm |
My dad bought a '53 WD, it had only been used as a demo by the dealer, I made a mistake and the block froze, I had a new block put in it, which raised the compression, then I had to put a 8 volt battery in it. If I remember right the lights still worked OK. The worse that might happen is the lamps might burn out.
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 88671 |
Posted: 28 Jul 2023 at 7:46pm |
Most of the new "LED" type bulbs will work 6-30 volts or 12-80 volt systems.. You can buy one with a case already installed and just BOLT ON... This one is SUPPOSE to replace your original bulb and use the old case.... maybe ?? .... from AMAZON..
I think the "PAR36" mean it puts out the equivalant of 36 WATTS ( on an incandesent bulb)..... but LED only pulls 5 Watts... or less than 1 amp each on a 8 v system.
Edited by steve(ill) - 28 Jul 2023 at 7:49pm |
steve(ill)
Posted: 28 Jul 2023 at 7:52pm |
this is what it says in the upper left corner...
steve(ill)
Posted: 28 Jul 2023 at 7:56pm |
One suggestion.. apparently you have had good luck with the 8 v in the past.. If you ever have a generator problem, or need a new battery...... i would consider updating to a 12 volt system.... New alternator for $100. .... battery for $100. ....new COIL $25.... starter and wiring are OK.
with a lot of new 48 v systems ( 6 x 8 volt) ........ maybe the battery selection will continue to be good ?? Edited by steve(ill) - 28 Jul 2023 at 7:58pm |
Steve in NJ
Joined: 12 Sep 2009 Location: Andover, NJ Points: 12027 |
Posted: 28 Jul 2023 at 8:15pm |
The 6V bulbs should be fine on 8V. It's when you throw 12V's to em' they go ka-blewy.. Steve@B&B
Dusty MI
Posted: 28 Jul 2023 at 8:21pm |
The old 6 volt generator will even put out enough to keep the 8 volt battery charged.
DrAllis
Posted: 29 Jul 2023 at 2:04am |
The old original 6 volt Delco generator works fine on my now 12 volt WD45 with a cut-out. Been this way for 11 years now.
Edited by DrAllis - 29 Jul 2023 at 2:05am |
Newwood
Joined: 09 Nov 2020 Location: Chapel Hill NC Points: 30 |
Posted: 29 Jul 2023 at 8:06am |
Dr. A: Well, that's interesting. I assume it still has a magnito ignition. Did you change to a 12v cutout?
Driverdan
Posted: 29 Jul 2023 at 9:11am |
Thank you guys for the responses !! The thought of making the lights work again never occurred to me because it has been like forever not working! I guess I will give it a shot and just see how it goes..thanks again, I appreciate true support. Dan
